17:22:07.5 07/10/2006: GameEx: Version 6.95: Starting Log
17:22:07.5 07/10/2006: Operating System Platform: Win32NT
17:22:07.5 07/10/2006: Operating System Name: Windows XP
17:22:07.5 07/10/2006: Operating System Version: 5.1.2600
17:22:07.5 07/10/2006: Checking for versions of .net Framework installed
17:22:07.5 07/10/2006: .net Framework 1.0 Installed
17:22:07.5 07/10/2006: .net Framework 1.1 Installed
17:22:07.5 07/10/2006: .net Framework 2.0 Installed
17:22:07.5 07/10/2006: Intel® Pentium® D CPU 2.80GHz
17:22:07.6 07/10/2006: 2.8Ghz - 2 Cores or CPU's
17:22:07.6 07/10/2006: Running Randomize()
17:22:07.6 07/10/2006: Checking for applications to Launch On Startup
17:22:07.6 07/10/2006: Initialising Video/MNG DLL's
17:22:07.6 07/10/2006: Running Misc startup tasks
17:22:07.6 07/10/2006: Setting Menu types
17:22:07.6 07/10/2006: Opening Configuration File
17:22:07.6 07/10/2006: Getting Configuration Values
17:22:07.7 07/10/2006: Using Theme: Default - Women We Love To Play
17:22:07.7 07/10/2006: Checking for alternate Image Directory for Theme: Default - Women We Love To Play
17:22:07.7 07/10/2006: Launching HideOS.exe
17:22:07.7 07/10/2006: Hiding Taskbar
17:22:07.7 07/10/2006: Is Media Center running?
17:22:07.7 07/10/2006: Media Center is running
17:22:07.8 07/10/2006: Checking/Creating LCD Registry values
17:22:07.8 07/10/2006: Check Media Center Exit/Start Mode
17:22:07.8 07/10/2006: Media Center Mode 2
17:22:07.8 07/10/2006: Closing Media Center
17:22:12.8 07/10/2006: Text/Language: English
17:22:12.8 07/10/2006: Applying Language/Text
17:22:13.3 07/10/2006: Snap Delay set to: 2
17:22:13.3 07/10/2006: Get other settings
17:22:13.5 07/10/2006: Set: Find emulator artwork on best match basis
17:22:13.6 07/10/2006: Start work for Form
17:22:13.6 07/10/2006: Getting Original Screen Size
17:22:13.6 07/10/2006: Loading ICON
17:22:13.7 07/10/2006: Initializing Component
17:22:13.7 07/10/2006: Initialising Bass Audio Library
17:22:14.1 07/10/2006: Loading default loading screen
17:22:14.2 07/10/2006: Loading Custom Emulators
17:22:14.2 07/10/2006: Loading Emulator 1: Nintendo 64 Games
17:22:14.4 07/10/2006: Error: Emulator_1: WorkingPath Does Not Exist
17:22:14.4 07/10/2006: --Please correct the error above for this emulator or disable the emulator.
17:22:14.4 07/10/2006: ---------------------------------
17:22:14.4 07/10/2006: Error: 5 - Procedure call or argument is not valid.
17:22:20.5 07/10/2006: ERRORS DETECTED: EXITING
Basically it means that the path you have set for Emulator 1 in the GameEx control panel is not correct.
So ether it must be corrected...or removed, from the control pannel.
