I searched the web for a possible solution but didnt find the right one for me... so here is the story:
I updated to the latest version from a very old one (my claim is normally never change a running system) because i wanted to go to pup player and updated my stuff, so anyway. Since updating i have the following problem, when starting any table with a ULTRA DMD only with Pinball X:
When i start the table, very fast the backglass and the Ultra DMD are loaded. But very late the table itself is loaded (this is not the biggest problem). The problem is, when it is loaded it doesnt has the focus and i have to click on the playfield to put coins in and so on. The interesting part is. When i start the table and exit it "hard", so the Ultra DMD doesnt gets closed like normal, and i then restart the table, the focus is on the table and the load is fast. i tried several reinstalls and so on. The problem does not occur at all if i load the table directly via Visual Pinball X, only with the frontend.
attached is the log when it doesnt has  the focus and the setting file. I already tried going back to the old version but it didnt help.
Specs of my system (didnt change since everything worked) Win10, 16Gb DDR4, I76800k, RTX2070, 2 Screens.
I hope someone has an idea. I am also confused that the UltraDMD is loaded much faster than the table, because when i load the table directly with VPX, it takes a while and the table is not far behind in loading.
Does Pinball X read the script ahead of the table or sth weird? i thought it should only tell VPX to load a specific table and then everything should be like opening it from VPX itself, but thats not the case here.
Tables without UltraDMD work like before and have full focus and so on.
Sorry for the long post. Maybe someone has an idea.
Thanks mates
Patrick
log.txt SetupWizard.log XDMDlog.txt PinballX.ini
Hey Thanks for the fast response, i thought i would wait some days at least;) no i really mean ultra DMD, the poper thing was my reason to update everything because it didnt work from the start but thats another story. the problem now is only with UltraDMD, i updated to the latest B2S server but this bug also appears without B2S backglass. The only constant in it is UltraDMD.
See if the fix here helps you;
If it does then i've no idea why it'd suddenly be a problem for you and need you to change tables scripts now.
I solved this problem with right click in B2S, click in "Start this Backglass in exe mode" and save changes.
Diablo, Kiss Tribute, Minions....
For Desktop Mode in HyperSpin i solved whit one script .ahk "wait and click" in RocketLauncher/Lib/User Functions.
The script. Wait 15 or 20 secs (you can modify acording your PC) and mouse click.
If table haven't B2S, after set other original tables, edit the file B2STableSettings.
You can View and end if file the tables what you have make changes in B2S.
Just copy and paste one of this Games after or before the Games and change game name for Game name needed.
I also dont know why this wasnt an issue before. but now its working like before. Thanks for your help everyone!
