Hi i have a little problem with my pinballx setup
I have all my tables vpt and vpx in 1 folder incl b2s
But when i open a vpx game in pinball x it goes to vpx drawing and i most manuel select THE good table
When i open a vpt table in pinballx iT open good and i can play that table
So what i am doing wrong?
Please attach (do not copy & paste) copies of your pinballx.ini and log.txt files for review. Thanks.
Easiest way is to split the files into 2 different folders.
1 for vpt and 1 for vpx.
Than create an extra system for vpt with the correct executable. And setup visual pinball system for vpx.
If you want to use all in 1 folder, you need to use alternate exe.
Setup default folder for where you have the most tables from in the folder (must be vpx) and do the vpt with alternate exe.
For easy use, use pinballx database manager
