I was wondering if it's possible to use a combination of buttons as an input. For instance, I want to use buttons X and E to enable the ingame CP viewer instead of just X.
One more question... I was wondering if it's possible to use 2 different keys to do the same thing. I have key 1 as my SELECT button but I also want key 7 as another SELECT button. Thanks in advanced for any replies!
-Billy B.
-Billy B.
I know you can change what buttons change the "Ingame CP viewer" from the gameex config. I'm not sure you can use a combination in that field. You could probably enable custom keyboard controls and do what you want.
