Hi there,
First post and have to say what a great frontend it is, I've installed it yesterday and I definetely want to donate once it works fine. I only have to correct one thing. I've got a NBA jam tournament edition cab with a j-pac and a Pentium 3 2.4ghz pc in the back and a Arcade VGA. Windows and Mame32 work both fine. The installation of GameEx went good as well the only thing now is that as soon as I start up GameEx and see the donate screen the colour white has dissapeared and it's then a little bit broken white/green/blue. I've tried to run with the ArcadeVGA and Without but no difference. As soon as I see the donate screen and I tab the windows button on the keyboard it gets all very clear and the white has returned but then GameEx failures with a directx error. I also tried to re-install Directx but that didn't workout as hoped. When I tried to run a few mame games it looks a little bit yellow/green as well so the white has dissapeared there as well. When I run it with Mame32 only so not without a frontend it works perfectly. Further GameEx is really the bomb also with all the features and extra emu's!!!
I hope someone can maybe help me out here.
Many thanks in advance
Regards Wouter
Look in the GameEx Control Panel and check your settings...maybe some thing is set wrong. Maybe check to make sure you have the correct build of .Net framework installed as well.
Hi there,
Regards Wouter
Some have reported turning OFF "Use Arcade Vga" setting in GameEx.
I've tried it now with the .net framework 1.1 and the 2.0 version and also
turning out the arcadevga in the GameEx cofiguration panel but no luck so far.
Any more advice is much appreciated
Which ones of the themes do you use? Perhaps you've selected a theme that forces a resolution your card can't display? Hope you get it sorted out!
Emph
I'm using the standard default, but I also tried other themes with other resolutions ?
I'm not understanding it anymore, because as soon as I'm returning to the standard XP desktop all the colors
are fine again?
Thanks for all the advice
are fine again?
In the gameex config. Under display settings. Is "Don't switch resolutions" on or off?
Is use 16 bit color on or off in gameex?
I tried both option in all sort of combination's but still no luck. The thing is when I'm in GameEx it looks al little bit old style (yellow green blue-ish) so no white and when I alt-tab to my desktop it's all good, so when I then alt-tab back it comes up 1 second good then it goes down and comes up again and gone is the white colour? What am I doing wrong? Nobody ever had this kind of thing before?
Again thanks for all of your help Much appreciated, I really want GameEx to work
Update Direct X? Update Graphics Driver? try uninstall of GameEx and reinstall. Delete all folders and files.
I've tried to update but then it says it has all components good (dirextc 9.0c) tried to uninstall en re-install, same problem :-(
Run GameEx
Close GameEx
Go to the GameEx program group in the start menu
Click on "Log file"
Copy contents and post in this thread
This will make things easier to narrow down your problems. And make sure to take note of any settings that you do after posting your Log file here in case someone can pinpoint your issue.
Edit: Also attach your GameEx.ini (found in CONFIG directory).
Emph
Run GameEx
Close GameEx
Click on "Log file"
Emph
Thanks will do when I'm home in about 6 hours from now.
p.s. is Windows 2000 maybe a solution?
If you're using an Arcade VGA card, I don't think changing OS will make any difference with your graphical issues. Are you using the latest drivers for your card? It sounds to me that this has to do with your GameEx configuration as you can run MAME32 and see your Windows desktop without problems.
Emph
here's mij log file and GameEx.ini
Again much appreciated
19:21:16.7 6-10-2006: GameEx: Version 6.93: Starting Log
19:21:16.8 6-10-2006: Operating System Platform: Win32NT
19:21:16.8 6-10-2006: Operating System Name: Windows XP
19:21:16.8 6-10-2006: Operating System Version: 5.1.2600
19:21:16.8 6-10-2006: Checking for versions of .net Framework installed
19:21:16.8 6-10-2006: .net Framework 1.1 Installed
19:21:16.8 6-10-2006: .net Framework 2.0 Installed
19:21:16.8 6-10-2006: Intel® Celeron® CPU 2.00GHz
19:21:16.8 6-10-2006: 1,99Ghz
19:21:16.8 6-10-2006: Running Randomize()
19:21:16.8 6-10-2006: Checking for applications to Launch On Startup
19:21:16.8 6-10-2006: Initialising Video/MNG DLL's
19:21:16.8 6-10-2006: Running Misc startup tasks
19:21:16.8 6-10-2006: Setting Menu types
19:21:16.8 6-10-2006: Opening Configuration File
19:21:16.8 6-10-2006: Getting Configuration Values
19:21:16.8 6-10-2006: Using Theme: Default - Default
19:21:16.8 6-10-2006: Checking for alternate Image Directory for Theme: Default - Default
19:21:16.8 6-10-2006: Launching HideOS.exe
19:21:16.8 6-10-2006: Hiding Taskbar
19:21:16.8 6-10-2006: Is Media Center running?
19:21:16.9 6-10-2006: Checking/Creating LCD Registry values
19:21:16.9 6-10-2006: Check Media Center Exit/Start Mode
19:21:16.9 6-10-2006: Media Center Mode 2
19:21:17.0 6-10-2006: Text/Language: English
19:21:17.0 6-10-2006: Applying Language/Text
19:21:17.2 6-10-2006: Snap Delay set to: 2
19:21:17.2 6-10-2006: Get other settings
19:21:17.3 6-10-2006: Set: Find emulator artwork on best match basis
19:21:17.3 6-10-2006: Start work for Form
19:21:17.3 6-10-2006: Getting Original Screen Size
19:21:17.3 6-10-2006: Loading ICON
19:21:17.3 6-10-2006: Initializing Component
19:21:17.3 6-10-2006: Initialising Bass Audio Library
19:21:17.5 6-10-2006: Loading default loading screen
19:21:17.5 6-10-2006: Loading Custom Emulators
19:21:17.7 6-10-2006: Using 2D Animations
19:21:17.7 6-10-2006: Using General Font: Trebuchet MS
19:21:17.7 6-10-2006: Using Title Font: Trebuchet MS
19:21:17.7 6-10-2006: Initialising DirectDraw
19:21:17.8 6-10-2006: Creating DirectDraw Device
19:21:17.8 6-10-2006: Using Device: Ultimarc ArcadeVGA
19:21:17.9 6-10-2006: Setting Resolution to 640x480 32 bit color
19:21:18.0 6-10-2006: Creating DirectDraw Surfaces
19:21:18.0 6-10-2006: Creating Primary Surface - Full Screen Mode
19:21:18.0 6-10-2006: Creating Back Buffer
19:21:18.0 6-10-2006: Loading graphic surfaces
19:21:18.1 6-10-2006: Creating Surfaces Misc and Dialogs
19:21:18.3 6-10-2006: Creating Surface Volume
19:21:18.3 6-10-2006: Creating Surfaces Arrows
19:21:18.3 6-10-2006: Creating Surfaces GameEXlogo Text
19:21:18.3 6-10-2006: Creating Surfaces Toolbar
19:21:18.3 6-10-2006: Creating Surfaces Backgrounds
19:21:18.5 6-10-2006: Creating Surfaces Toolbar Controls
19:21:18.5 6-10-2006: Creating Surfaces GameEx Logo
19:21:18.5 6-10-2006: Creating Surfaces Home & Exit
19:21:18.6 6-10-2006: Creating Surfaces Snaps
19:21:18.6 6-10-2006: Creating Surfaces Menu and List Bars
19:21:18.7 6-10-2006: Creating Fonts
19:21:18.7 6-10-2006: Creating Menu Font
19:21:19.0 6-10-2006: Creating Game Font
19:21:19.1 6-10-2006: Creating Font Black
19:21:19.4 6-10-2006: Creating Font Black Small
19:21:19.7 6-10-2006: Creating Game Font Faded
19:21:19.8 6-10-2006: Creating Title Font
19:21:19.9 6-10-2006: Restoring Title Font From Cache
19:21:20.0 6-10-2006: Fonts Created Succesfully
19:21:44.1 6-10-2006: Initialising Windows Media Player Component
19:21:44.2 6-10-2006: MAME Path is: C:\Mame
19:21:44.2 6-10-2006: MAME EXE file is: mame.exe
19:21:44.2 6-10-2006: ROM Path is: C:\Mame\roms
19:21:44.2 6-10-2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
19:21:44.2 6-10-2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
19:21:44.2 6-10-2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
19:21:44.2 6-10-2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
19:21:44.2 6-10-2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
19:21:44.2 6-10-2006: Loading Controls.ini map file
19:21:44.3 6-10-2006: Snap Path is: C:\Emulators\Mame32\snap
19:21:44.3 6-10-2006: AVI Snap Path: Not Found
19:21:44.3 6-10-2006: Flyer Path is: C:\Emulators\Mame32\flyers
19:21:44.3 6-10-2006: Cabinet Path is: C:\Emulators\Mame32\cabinets
19:21:44.3 6-10-2006: Title Path is: C:\Emulators\Mame32\titles
19:21:44.3 6-10-2006: Panel Path is: C:\Emulators\Mame32\cpanel
19:21:44.3 6-10-2006: Icon Path: Not Found
19:21:44.3 6-10-2006: Marquee Path is: C:\Emulators\Mame32\marquees
19:21:44.3 6-10-2006: Using Ultimarc AradeVGA
19:21:44.3 6-10-2006: MAME CMD options: -triplebuffer -nowindow -joy
19:21:44.3 6-10-2006: Attempting to load game list
19:21:44.4 6-10-2006: Loading last used Game List
19:21:44.5 6-10-2006: Setting Music Volume
19:21:44.5 6-10-2006: Creating DirectSound Device
19:21:44.5 6-10-2006: Trying: Primair geluidsstuurprogramma
19:21:44.5 6-10-2006: Loading Sound Files
19:21:44.6 6-10-2006: DirectSound Device Created Successfully
19:21:44.6 6-10-2006: Initialising DirectInput for Gamepad support
19:21:44.7 6-10-2006: Unable to create a joystick device
19:21:44.8 6-10-2006: Playing intro sound file
19:21:44.8 6-10-2006: Initializing MCE Remote
19:21:44.8 6-10-2006: Initialization OK! Starting GameEx!
19:21:44.8 6-10-2006: Testing Main Loop Once: Processing Frame
19:21:45.5 6-10-2006: Testing Main Loop Once: Main Loop ran successfully
19:21:53.3 6-10-2006: Exiting GameEx!
19:21:53.4 6-10-2006: Saving Settings
19:21:55.0 6-10-2006: Checking for applications to Launch On Exit
Cope_of_GameEx.ini.txt
"640x480 32 bit color" is that what you're running successfully for Windows as well?
Emph
Emph
indeed no problem, should I downsize it to 16 bit and a other resolution?
Someone correct me if I'm wrong but shouldn't an arcade vga card be set to like 640 by 288 or something? Is this the windows resolution of an arcade vga or is this the resolution that changes when a game is started? My arcade vga settings are turned off in my config since I don't have one but the default settings in my config are stretch x 640 stretch y 288. I don't know if this helps you or not but check out your arcade vga settings in the config. This is just a longshot though as I don't see how this would mess up your colors.
Good luck
Jay T
Good luck
Jay T
I don't have an ArcadeVGA card unfortunately, so I'm kinda reaching blindly in the dark here. :) But I assumed that his 640 x 480 was interlaced. I know that arcade monitors can display that resolution so I assumed that was it. Any news on this, wouter?
Emph
Emph
I've turned 32 to 16 bit, but How do I change the resolution of the Arcade VGA because in the windows settings this is the lowest the choose from? The bit weren't helping because I still have the same problem
In GameEX display settings choose a theme with 640 x 288. This should work, but like I said before, I don't own an ArcadeVGA. :unsure:
Have you tried installing Ultimarc's Quickrez? http://www.ultimarc.com/quickres.exe
Install it, put a shortcut in your autostart folder on your start menu. Then click on the icon that looks like a Galaga ship in your system tray to choose from the supported video modes for your ArcadeVGA.
Also, make sure that you've installed it correctly -> http://www.ultimarc.com/avgainst.html (See Windows XP installation a bit down on that page).
Emph
Seems to be working perfectly, I'm going to play a little bit further and ofcourse buy the progam
Many many thanks for all your help!!
So what did you do to get it working? Changed theme?
Emph
Emph
Re-installed the driver and the galaga ship was already there, I first tried with a 640X288 theme but also other themes are working perfectly now :-) So I was just following the instructions from the beginning again.
I'm totally happy because I think it's the best frontend on the market!!!!!!!
Many thanks again for all the help!
