Hi Guys,
Just set up my 24" recroom master cabinet- Got pinball X and Visual Pin 9 and Visual Pin X-  I am doing ok so far getting everything set up (this is fun and will be my new addiction)- I believe I need to do something with my button Config-  When I am trying to exit a table in Pinball X, my DEBUG/Editor pops up from Visual pinball and I am forced to exit Visual pinball and go to the table editor screen.
What is the proper key setup for me to exit a table in Pinball X while running a visual pinball table?  Thank you - Kevin
Within pinballx there is an exit key. This exit the emulator, but also exit the system and can even exit PinballX
Thank you Mike- I believe I have the Escape key programmed in visual pinball to exit the table- I will try programming a different key in Pinball X- That might be my problem if I have the Escape key mapped to exit visual Pinball and pinball X?
It should not be the case. I have esc also mapped and closes vp. Try to launch pbx as admin and try again
If you running as admin, please do an exit during game and after that post you log txt and pinballx.ini (as attachment)
