i have my ipac wired up and the button i want to use for select in game ex is the comma. (,). i went into custom keyboard input and for select it's 30, i'm guessing that's enter. anyone know the # on the keyboard for comma?
umm...I believe there is a file in that same directory as the custom input file that contains all the scan codes. Does it not have comma?
The Setup Wizard should help with configuring keys because it has a key config section where you can input the key you want by pressing it. There is no need to manually edit custominput.ini anymore.
