Hot To Exit Out of Project64 With an X-Arcade Solo
I currently have GameEx (6.80) working perfectly with numerous Emu's (Atari, VisualBoy, etc.) without any problems. I also have it working just fine with Project64 1.6. However, once I launch a game in Project64, I am unable to exit out of the Emu without physically hitting ESC on a nearby keyboard. On every other Emu I could change the Exit key to match what I want to use it on X-Arcade Solo (the lower right Pinball flipper button - Which is set to the number 4 ). My GameEx config is below:
[Emulator_1]
STARTPAGENAME=Nintendo 64 Games
TITLETEXT=N64
StartPageLogo=n64
ROMFilter=*.zip
RomsInFolders=False
RomPath=C:\MAME\NINTENDO64\roms
SnapPath=C:\MAME\NINTENDO64\snaps
TitlePath=C:\MAME\NINTENDO64\titles
BoxPath=C:\MAME\NINTENDO64\boxart
CartPath=C:\MAME\NINTENDO64\cartridges
WorkingPath=C:\MAME\NINTENDO64
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=n64x
AlsoLaunch=
Command=Project64.exe [ROMPath]\[RomFile]
OLDatZip=C:\Program Files\OfflineList0.7\datas\n64_OL.zip
LaunchBefore=
LaunchAfter=
configFile=Project 64 V2
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=N64
GamesIn7Zips=
PlayInScreenSaver=True
[GENERAL]
DumbyValue=
I am running Windows MCE and by enabling the config file to match the Project64 V2.ini file, I can also use the BACK button on the MCE remote as well as the ESC key on the keyboard, but what a pain. I have scoured these forums with users suggesting the AUTOHOTKEY program, but there has to be a simpler way. Does anyone have additional syntax that I could add to the Project64 V2 file to accomplish this simple task using the button on the X-arcade Solo Controller?
Thanks again.
Pancho
Hi,
By default, you should be able to trigger the escape key on your X-Arcade by pressing Start 2 and your right Pinball-button simultaneously. I don't know if this works on a solo, but that's the case for my dual. Otherwise I would recommend you to reprogram that button to "Escape" using a PS/2-keyboard plugged into your X-Arcade and your manual -> http://www.xgaming.com/service/ServiceFile...anual%20USA.pdf .
It's very easy to remap the buttons on your X-Arcade, and they stay mapped. Good luck.
Emph
