[RESOLVED] Pinball fx2 and Joytokey problem through Pinballx
This problem may be old news to some of you, but im very new to virtual pinball so im hoping to get some help. Im using Joytokey to map controls to pinball fx2 through Pinballx (runing as administrator). Joytokey works when I launch outside of pinballx, but wont work if i launch through Pinballx. But.... If I turn of "run as administrator" for Pinballx it works fine, but then Visual pinball and future pinball wont work properly through Pinballx. I hope this is a common problem with an equally common solution. any help would be greatly appreciated
What else is set to run as admin (FP, VP, JoyToKey)?
Also, did you try running joytokey as at windows startup (rather than launching with FX2 which it sounds like you do now as  a launch before task)
Guys, Thank you both for your help. What I found that worked was turning all of the programs and components for all of my pinball systems "running as admin" off, All of it works perfectly now, go figure. Thank you you both again for the quick and helpful responses.
