I'm having an issue. I used to have all my tables from both vpx and fx3 all in the menu together. Now when i open pinballx it asks to pick a system. Then i can't go back to change between the two. Tried every setting under general tab. Could use some help. Thanks.
  1. Give a brief description of you sytem setup (2/3 screen setup, feedback, addressable leds) 3 screen setup. No extras.
  2. Are you using any 3rd party add-ons (dmdext, doflinx, PUplayer) Use PU player
  3. Define which emulator you are having issues with (VPX, Future Pinball, FX3) Issue with PinballX specifically
  4. Is the issue table specific or an issue for all tables? If so please state the table name. N/A
  5. Does this issue occur only when launching the game via PBX? no
  6. What Version of PBX are you on? 4.13
log.txt PinballX.ini
