Hiya Folks and Tom!
I have noticed, that about every other upgrade I install (automatically) I get a continual message that there are upgrades available, no matter whether or not I have upgraded. I have tried to download and then install, removing the auto function out of the equation, it still does not work. Like I said, it appears to happen every other version. When I try to use the downloaded file, it errors out. Any ideas??
Try disabling auto update option from within the Gamex Config and do manual downloads from the front of Tom's Gamex site instead. I do use the auto update option on a pc here and download it on another. Maybe your antivirus is timing out the download or sumat?
Will give it a try..just weird how it only happens every other update.... :angry:
