This is the error message I am getting.
21:40:44.1 9/26/2006: Version 2 Theme being used. Loading.
21:40:44.1 9/26/2006: Loading Button Data
21:40:44.1 9/26/2006: Loading Font Data
21:40:44.1 9/26/2006: Loading Layout Data
21:40:44.1 9/26/2006: Loading Taskbar Data
21:40:44.2 9/26/2006: Error: One or more theme objects were outside the bounds of the resolution
21:40:44.2 9/26/2006: Error: 5 - Argument 'Number' is not a valid value.
21:40:48.3 9/26/2006: ERRORS DETECTED: EXITING
Could it be due to the fact I upgraded my monitor from 16" to 19" widescreen. If so, how do I fix the error.
Thank you
Well I'm not sure if its the theme doesn't support the resolution that your currently set at...or if GameEx needs to be set to fuction in a resolution supported by your monitor. Any ways try going to the "Display Settings" page in the GameEx control panel and make sure X&Y resolutions are set to values supported by your monitor...if it is...maybe try a different one...that may behave better with the theme you are using.
keep in mind this is all guess work on my part...and no actual experince with this matter...so you may want to search the forum for other like subjects posted in the past here.
Tried downloading the theme again, didn't fix it, so I went back to the default theme. Not very many that support 1440x900
Could be a rounding bug or something for the bounds checking. Hopefully Tom will read the thread and check it out.
