hi all
I seem to be having trouble getting pinballx to show up my Stern arcade tables its not even showing any other system in my systems category
you need to create a database manually the tables don't auto list themselves in game manager. Also stern pinball arcade does not have any commandline parameters to launch a table they just don't support it.
On the other hand if you just want to launch stern pinball arcade add one table in game manager under the stern pinball arcade system (name it stern pinball arcade) and if you select it it will launch stern pinball arcade with how you have it setup currently. But if you want be able to launch tables directly from within pinballx for stern pinball arcade it would require scripts to control stern pinball arcade, like launch the game and select the tables based on parameters. But looking at the setup you did i'm guessing you only want to launch the game from within pinballx with no table selection
it's also possible a system does not show up in system menu if it does not have any tables listed, but i did not verify that
if you want to launch tables directly freecammod supports stern pinball arcade using -stern parameter but i have not tested this as i don't own the tables in pinball aracde. I do use freecammod for the pinball arcade (not stern pinball arcade) and i got it working more or less fine (only sporadically i need to use my mouse to select something) so it is an option if you want to be able to launch tables directly for stern pinball arcade
Edit: sorry i'm wrong it seems they have removed stern pinball arcade support :(
Edit2: it seems i do own the tables now, i had bought all tables on pinball arcade and now when logging in using same account my tables got unlocked in stern pinball arcade as well (this did not work a few months ago with me)
