Ok..so I've tried getting Atari Jaguar working and I've D/L the rom sets and also I've got a few CD images, too.
How many of these games really do work?
Seems like it's a real crap shoot on getting games working. Is everyone using Project Tempest or what?
I'd like some ideas, please.
The roms in general are okay at best...the cd's tho are more or less a waste of time currently...maybe when and if the emu's for it improve will things change.
I'm currently using PT...tho I may try some of the others and see how they fair.
Virtual Jaguar here and yes... It's pretty much a crapshoot. :(
Well I personally haven't played them any wheres close enough to say whats good and whats bad...and more to the point I have no interest in giving you a sales pitch.
If you want to ditch the Jag then do so...most of the games are available on other plateforms that are better supported any ways.
To me the only reason to have the Jag is just pure geek factor of having it and being able to play a handful of games on it.
My point of view tho.
I agree. I've never used it - just like to see my collection and show off what I have when people come to use GameEx. Matter of fact, I use the Lynx more often.
The system was a lemon really. :)
There is only a limit if you are inputting each of your emulator configs from the GameExConfig. You can add as many as you like if you type them directly into the GameEx.ini file (This is in GameEx\Config\gameex.ini). I currenttly have about 50 setup. But this is due to wanting different regions roms separate from each other (Example one for Japanese Snes roms,one for U.S.A. snes roms)
Any emulators added after 28 will not show on the advanced emulator config though. So if there are any amendments needed you will have to close down GameEx, change the .ini file and restart to see if your changes have worked.
Lastly you may find after an update the order your emulators are listed in the .ini file may have moved (Normally pushed to the bottom, but sometimes put in a non-numerical way.) This dosent affect the order they are listed when using GameEx or the way they function.
Hope that made sense.
J. :)
Lol, I've not looked at the jaguar emus, think I'll hold off now!
Thanks!
