Found a minor bug with the screensaver, no worries, but just reporting...
If you have the screensaver OFF in config, but show Start Screensaver menu ON, you can reproduce the following behaviour:
Load GameEx and start the screensaver (I was showing friends the functionality, but don't use it myself normally).
The screensaver starts fine. When you exit the screensaver it exits fine, but after 3-4 seconds it comes back on again! It will do this repeatedly. You can even EXIT GameEx and reach the windows desktop and the screensaver will still fire up!!! After a couple of rounds of this, GameEx crashes and you get control of your machine back.
Repeatable with latest version. Doesn't happen if screensaver set to 2 mins or whatever in config.
Shaun
