Since I have updated to the latest version of PinballX it now keeps showing the PinballX animation on my RealDMD.
I don't card about that one way or another but the DMD used to tuen off for tables that did't use it.
Now it just freezes in the middle of the animation.
Is there a way to get back to the older behaviors of turning off the DMD display when it isn't being used?
I think I was on 3.37 and now I'm using 3.40.
Hide DMD is checked on all the tables.
When I turn the PC on it says PinDMD.com Rev598-16
In device manager it says pinDMD2
14:08:41.2  5/13/2019:  PinballX - Version 3.40
14:08:58.6  5/13/2019:  Windows 7 Home Premium Service Pack 1 64-bit (4GB)
14:08:58.6  5/13/2019:  Loading Settings
14:08:58.7  5/13/2019:  Loading Settings
14:09:00.1  5/13/2019:  Initialize Component
14:09:00.5  5/13/2019:  Initialize Display
14:09:02.1  5/13/2019:  Machine just booted so waiting 6 seconds for screens and startup programs. Boot Time = 5/13/2019 2:07:55 PM
14:09:08.1  5/13/2019:  Testing Flash engine.
14:09:09.5  5/13/2019:  Loading PlugIns
14:09:11.9  5/13/2019:  Created DirectX BackGlass Window
14:09:11.9  5/13/2019:  Looking for startup images
14:09:12.2  5/13/2019:  Hiding Cursor
14:09:12.2  5/13/2019:  Hiding Taskbar
14:09:12.3  5/13/2019:  Getting GPU and CPU Information
14:09:12.3  5/13/2019:  CPU:  Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz
14:09:12.3  5/13/2019:  4 cores, 4 threads
14:09:12.3  5/13/2019:  GPU 1: NVIDIA GeForce GTX 750 Ti
14:09:12.3  5/13/2019:  Displays: 2
14:09:12.3  5/13/2019:  Load Game List
14:09:12.3  5/13/2019:  Loading Database: Future Pinball
14:09:12.3  5/13/2019:  Loading Database: Visual Pinball
14:09:12.4  5/13/2019:  Loading Database: VPX
14:09:12.5  5/13/2019:  Initial load gamelist took: 203ms
14:09:12.6  5/13/2019:  Finding and matching artwork and videos
14:09:19.9  5/13/2019:  Took: 7379ms
14:09:19.9  5/13/2019:  Loading Game Statistics and Scores
14:09:19.1  5/13/2019:  Real DMD Initialized
14:09:20.0  5/13/2019:  Main display running full screen windowed.
14:09:20.0  5/13/2019:  Loading Surfaces
14:09:20.2  5/13/2019:  Finished Loading Surfaces
14:09:20.2  5/13/2019:  Initialize Audio
14:09:20.3  5/13/2019:  Set Keyboard Controls
14:09:20.3  5/13/2019:  Initialize Joystick
14:09:20.4  5/13/2019:  1 Joystick Attached
14:09:20.4  5/13/2019:  Started
14:09:21.1  5/13/2019:  Starting Real DMD Thread
14:09:49.9  5/13/2019:  Exiting
14:09:49.9  5/13/2019:  Showing Taskbar
14:09:49.9  5/13/2019:  Unhiding Mouse Cursor
14:09:49.9  5/13/2019:  Disposing Plugins
14:09:49.9  5/13/2019:  Saving Settings
14:09:49.9  5/13/2019:  Waiting for Online Thread
14:09:49.1  5/13/2019:  Showing Taskbar
14:09:49.1  5/13/2019:  Unhiding Mouse Cursor
14:09:49.1  5/13/2019:  Disposing Plugins
14:09:49.1  5/13/2019:  Saving Settings
14:09:49.1  5/13/2019:  Waiting for Online Thread
14:09:54.8  5/13/2019:  Bye
14:09:56.3  5/13/2019:  Bye
Beats me.
I deleted the old log file then started PinballX again and got this:
15:12:23.3  5/13/2019:  PinballX - Version 3.40
15:12:23.4  5/13/2019:  Windows 7 Home Premium Service Pack 1 64-bit (4GB)
15:12:23.4  5/13/2019:  Loading Settings
15:12:23.4  5/13/2019:  Initialize Component
15:12:23.4  5/13/2019:  Initialize Display
15:12:23.5  5/13/2019:  Testing Flash engine.
15:12:24.5  5/13/2019:  Loading PlugIns
15:12:24.6  5/13/2019:  Created DirectX BackGlass Window
15:12:24.6  5/13/2019:  Looking for startup images
15:12:24.8  5/13/2019:  Hiding Cursor
15:12:24.8  5/13/2019:  Hiding Taskbar
15:12:24.8  5/13/2019:  Getting GPU and CPU Information
15:12:24.8  5/13/2019:  CPU:  Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz
15:12:24.8  5/13/2019:  4 cores, 4 threads
15:12:24.8  5/13/2019:  GPU 1: NVIDIA GeForce GTX 750 Ti
15:12:24.8  5/13/2019:  Displays: 2
15:12:24.8  5/13/2019:  Load Game List
15:12:24.8  5/13/2019:  Loading Database: Future Pinball
15:12:24.8  5/13/2019:  Loading Database: Visual Pinball
15:12:24.8  5/13/2019:  Loading Database: VPX
15:12:24.9  5/13/2019:  Initial load gamelist took: 78ms
15:12:24.9  5/13/2019:  Finding and matching artwork and videos
15:12:26.5  5/13/2019:  Took: 1638ms
15:12:26.5  5/13/2019:  Loading Game Statistics and Scores
15:12:26.6  5/13/2019:  Real DMD Initialized
15:12:26.6  5/13/2019:  Main display running full screen windowed.
15:12:26.6  5/13/2019:  Loading Surfaces
15:12:26.6  5/13/2019:  Finished Loading Surfaces
15:12:26.6  5/13/2019:  Initialize Audio
15:12:26.6  5/13/2019:  Set Keyboard Controls
15:12:26.6  5/13/2019:  Initialize Joystick
15:12:26.7  5/13/2019:  1 Joystick Attached
15:12:26.7  5/13/2019:  Started
15:12:27.4  5/13/2019:  Starting Real DMD Thread
15:12:34.7  5/13/2019:  Exiting
15:12:34.7  5/13/2019:  Showing Taskbar
15:12:34.8  5/13/2019:  Unhiding Mouse Cursor
15:12:34.8  5/13/2019:  Disposing Plugins
15:12:34.8  5/13/2019:  Saving Settings
15:12:34.8  5/13/2019:  Bye
I have never had this issue until I did this last upgrade on Sunday.
With that new DLL it now works like it used to most of the time. Not all of the time.
But it is definitely a step in the right direction....
No changes at all.
I played some tables and it was all normal, noticed the message that there was an upgrade available, installed the upgrade and immediately noticed the difference.
I was all Windows updates disabled so that can't be it either....
Not to ask a stupid question but is there a way to just turn the whole RealDMD off in PinballX?
At this point those little animations are more problems than they are worth....
