Hi everyone -
I'm new to GameEx - just installed it yesterday and am having problems with getting the program to display on the secondary monitor (TV) with MCE 2005 in Dual View.
I've set GameEx in the configuration file to have "Display on Secondary Display" as "Yes". It didn't want to work at first - kept putting the software up on the monitor instead of the TV. Then I switched back to a single view with one monitor and switched it back so that the monitor was the primary display and the TV was the secondary.This time GameEx opened the "wait" screen and then froze after a general exception... a series of them, actually.
Anyone have any ideas about how i can get this to work?
lemme try, i have a dual monitor option, but only use it as a tv out for my cabinet.
do you mean dual as in clone? like having it displayed on both, or dualview as in dragging the mouse over to the other monitor?
log?
no - not a clone display... a dual desktop, each with it's own properties and display.
here's the log of the error i get when trying to force GameEx to the secondary display (the TV).
fyi - since i'm still trying out this software, i only have it linked to one N64 emulator - no MAME or anything else.
21:51:47.7 8/31/2006: GameEx: Version 6.69: Starting Log
21:51:47.8 8/31/2006: Operating System Platform: Win32NT
21:51:47.8 8/31/2006: Operating System Name: Windows XP
21:51:47.8 8/31/2006: Operating System Version: 5.1.2600
21:51:47.8 8/31/2006: Checking for versions of .net Framework installed
21:51:47.8 8/31/2006: .net Framework 1.0 Installed
21:51:47.8 8/31/2006: .net Framework 1.1 Installed
21:51:47.8 8/31/2006: .net Framework 2.0 Installed
21:51:47.8 8/31/2006: AMD Athlon 64 X2 Dual Core Processor 3800+
21:51:47.8 8/31/2006: 2.01Ghz - 2 Cores or CPU's
21:51:47.8 8/31/2006: Running Randomize()
21:51:47.8 8/31/2006: Checking for applications to Launch On Startup
21:51:47.8 8/31/2006: Initialising Video/MNG DLL's
21:51:47.8 8/31/2006: Running Misc startup tasks
21:51:47.8 8/31/2006: Setting Menu types
21:51:47.8 8/31/2006: Opening Configuration File
21:51:47.8 8/31/2006: Getting Configuration Values
21:51:47.8 8/31/2006: Using Theme: Default - MCE Glossy
21:51:47.8 8/31/2006: Checking for alternate Image Directory for Theme: Default - MCE Glossy
21:51:47.8 8/31/2006: GameEx will display on Secondary Device
21:51:47.8 8/31/2006: Is Media Center running?
21:51:47.9 8/31/2006: Media Center is running
21:51:47.9 8/31/2006: Checking/Creating LCD Registry values
21:51:47.9 8/31/2006: Check Media Center Exit/Start Mode
21:51:47.9 8/31/2006: Media Center Mode 2
21:51:47.9 8/31/2006: Closing Media Center
21:51:52.8 8/31/2006: Text/Language: English
21:51:52.8 8/31/2006: Applying Language/Text
21:51:52.9 8/31/2006: Snap Delay set to: 2
21:51:52.9 8/31/2006: Get other settings
21:51:53.0 8/31/2006: Set: Find emulator artwork on best match basis
21:51:53.0 8/31/2006: Start work for Form
21:51:53.0 8/31/2006: Getting Original Screen Size
21:51:53.0 8/31/2006: Loading ICON
21:51:53.0 8/31/2006: Initializing Component
21:51:53.0 8/31/2006: Initialising Bass Audio Library
21:51:53.1 8/31/2006: Loading default loading screen
21:51:53.2 8/31/2006: Loading Custom Emulators
21:51:53.2 8/31/2006: Loading Emulator 1: Nintendo 64 Games
21:51:53.2 8/31/2006: Using 2D Animations
21:51:53.3 8/31/2006: Using General Font: Trebuchet MS
21:51:53.3 8/31/2006: Using Title Font: Trebuchet MS
21:51:53.3 8/31/2006: Initialising DirectDraw
21:51:53.3 8/31/2006: Creating DirectDraw Device: Secondary Device
21:51:53.3 8/31/2006: Using Device: NVIDIA GeForce 7600 GT
21:51:53.3 8/31/2006: Creating DirectDraw Surfaces
21:51:53.3 8/31/2006: Creating Primary Surface - Windowed Mode
21:51:53.4 8/31/2006: Creating Back Buffer
21:51:53.4 8/31/2006: Loading graphic surfaces
21:51:53.4 8/31/2006: Creating Surfaces Misc and Dialogs
21:51:53.5 8/31/2006: Creating Surface Volume
21:51:53.5 8/31/2006: Creating Surfaces Arrows
21:51:53.5 8/31/2006: Creating Surfaces GameEXlogo Text
21:51:53.5 8/31/2006: Creating Surfaces Toolbar
21:51:53.5 8/31/2006: Creating Surfaces Backgrounds
21:51:53.6 8/31/2006: Creating Surfaces Toolbar Controls
21:51:53.7 8/31/2006: Creating Surfaces GameEx Logo
21:51:53.7 8/31/2006: Creating Surfaces Home & Exit
21:51:53.7 8/31/2006: Creating Surfaces Snaps
21:51:53.7 8/31/2006: Creating Surfaces Menu and List Bars
21:51:53.8 8/31/2006: Creating Fonts
21:51:53.8 8/31/2006: Creating Menu Font
21:51:53.8 8/31/2006: Creating Game Font
21:51:53.9 8/31/2006: Creating Font Black
21:51:54.0 8/31/2006: Creating Font Black Small
21:51:54.1 8/31/2006: Creating Game Font Faded
21:51:54.2 8/31/2006: Creating Title Font
21:51:54.2 8/31/2006: Restoring Title Font From Cache
21:51:54.2 8/31/2006: Fonts Created Succesfully
21:52:18.3 8/31/2006: Initialising Windows Media Player Component
21:52:18.4 8/31/2006: Loading Controls.ini map file
21:52:18.4 8/31/2006: MAME CMD options: -triplebuffer -nowindow -joy
21:52:18.4 8/31/2006: Attempting to load game list
21:52:18.4 8/31/2006: Loading last used Game List
21:52:18.4 8/31/2006: Loading Start Page
21:52:18.5 8/31/2006: Setting Music Volume
21:52:18.5 8/31/2006: Creating DirectSound Device
21:52:18.5 8/31/2006: Trying: Primary Sound Driver
21:52:18.5 8/31/2006: Loading Sound Files
21:52:18.6 8/31/2006: DirectSound Device Created Successfully
21:52:18.6 8/31/2006: Initialising DirectInput for Gamepad support
21:52:18.7 8/31/2006: Unable to create a joystick device
21:52:18.7 8/31/2006: Playing intro sound file
21:52:18.7 8/31/2006: Initializing MCE Remote
21:52:18.7 8/31/2006: Initialization OK! Starting GameEx!
21:52:18.7 8/31/2006: Testing Main Loop Once: Processing Frame
21:52:19.0 8/31/2006: Testing Main Loop Once: Main Loop ran successfully
21:52:19.3 8/31/2006: Loading Emulators On thread
21:52:19.3 8/31/2006: Validating: Emulator_1: Custom Background:
21:52:19.3 8/31/2006: Warning: Emulator_1: Custom Background Does not exist
21:52:19.3 8/31/2006: Validating: Emulator_1: Snap Path:
21:52:19.3 8/31/2006: Warning: Emulator_1: Snap Path Does not exist
21:52:19.3 8/31/2006: Validating: Emulator_1: Database: N64
21:52:19.3 8/31/2006: Validating: Emulator_1: Title Snap Path:
21:52:19.3 8/31/2006: Warning: Emulator_1: Title Snap Path Does not exist
21:52:19.3 8/31/2006: Validating: Emulator_1: Box Art Path:
21:52:19.3 8/31/2006: Warning: Emulator_1: Box Art Path Does not exist
21:52:19.3 8/31/2006: Validating: Emulator_1: Cart Art Path:
21:52:19.3 8/31/2006: Warning: Emulator_1: Cart Art Path Does not exist
21:52:19.3 8/31/2006: Loading OfflineList Dat File for emulator: 1
21:52:19.3 8/31/2006: Cannot Find Offline List Dat File
21:52:19.3 8/31/2006: Loading OfflineList Dat File for emulator: 2
21:52:19.5 8/31/2006: Loading OfflineList Dat File for emulator: 25
21:52:19.5 8/31/2006: Cannot Find Offline List Dat File
21:52:19.6 8/31/2006: 21 Consecutive Exceptions Occured: Exiting
21:52:19.6 8/31/2006: Error in the application.
21:52:19.6 8/31/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
21:52:19.6 8/31/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
21:52:19.6 8/31/2006: at GameEx.GameEx.mainform.DisplayFrame()
Try telling GameEx not to change resolution. What resolutions are the displays running at?
right now i have my primary monitor (desktop) at 1024x768 and the secondary (TV) at 720x480.
let me try that and see what happens.
if it doesn't work, i'll try setting it to 640x480 too.
interesting - the same thing happened, but now i get a different log file. (below)
i set GameEx to not change resolutions, and set the standard resolution to 720x480.
when i select "My Games" and press the OK button, there's a pause, then MCE shuts down on my secondary display and the "splash" screen for GameEx pops up on my primary display. then, after the wait period, the splash screen disappears and the error log pops up on my primary display, at which point MCE restarts itself on the secondary display.
i'll try changing the resolution to 640x480 or 800x600 and see if i can get different results.
here's the log file...
17:46:52.0 9/1/2006: GameEx: Version 6.69: Starting Log
17:46:52.0 9/1/2006: Operating System Platform: Win32NT
17:46:52.0 9/1/2006: Operating System Name: Windows XP
17:46:52.0 9/1/2006: Operating System Version: 5.1.2600
17:46:52.0 9/1/2006: Checking for versions of .net Framework installed
17:46:52.0 9/1/2006: .net Framework 1.0 Installed
17:46:52.0 9/1/2006: .net Framework 1.1 Installed
17:46:52.0 9/1/2006: .net Framework 2.0 Installed
17:46:52.0 9/1/2006: AMD Athlon 64 X2 Dual Core Processor 3800+
17:46:52.0 9/1/2006: 2.01Ghz - 2 Cores or CPU's
17:46:52.0 9/1/2006: Running Randomize()
17:46:52.0 9/1/2006: Checking for applications to Launch On Startup
17:46:52.0 9/1/2006: Initialising Video/MNG DLL's
17:46:52.0 9/1/2006: Running Misc startup tasks
17:46:52.0 9/1/2006: Setting Menu types
17:46:52.0 9/1/2006: Opening Configuration File
17:46:52.0 9/1/2006: Getting Configuration Values
17:46:52.0 9/1/2006: Using Theme: Default - MCE Glossy
17:46:52.0 9/1/2006: Checking for alternate Image Directory for Theme: Default - MCE Glossy
17:46:52.0 9/1/2006: GameEx will display on Secondary Device
17:46:52.0 9/1/2006: Is Media Center running?
17:46:52.0 9/1/2006: Media Center is running
17:46:52.0 9/1/2006: Checking/Creating LCD Registry values
17:46:52.0 9/1/2006: Check Media Center Exit/Start Mode
17:46:52.0 9/1/2006: Media Center Mode 2
17:46:52.0 9/1/2006: Closing Media Center
17:46:57.0 9/1/2006: Text/Language: English
17:46:57.0 9/1/2006: Applying Language/Text
17:46:57.1 9/1/2006: Snap Delay set to: 2
17:46:57.1 9/1/2006: Get other settings
17:46:57.1 9/1/2006: Set: Find emulator artwork on best match basis
17:46:57.1 9/1/2006: Start work for Form
17:46:57.1 9/1/2006: Getting Original Screen Size
17:46:57.1 9/1/2006: Loading ICON
17:46:57.2 9/1/2006: Initializing Component
17:46:57.2 9/1/2006: Initialising Bass Audio Library
17:46:57.3 9/1/2006: Loading default loading screen
17:46:57.3 9/1/2006: Loading Custom Emulators
17:46:57.3 9/1/2006: Loading Emulator 1: Nintendo 64 Games
17:46:57.4 9/1/2006: Using 2D Animations
17:46:57.4 9/1/2006: Using General Font: Trebuchet MS
17:46:57.4 9/1/2006: Using Title Font: Trebuchet MS
17:46:57.4 9/1/2006: Initialising DirectDraw
17:46:57.4 9/1/2006: Creating DirectDraw Device: Secondary Device
17:46:57.4 9/1/2006: Using Device: NVIDIA GeForce 7600 GT
17:46:57.5 9/1/2006: Creating DirectDraw Surfaces
17:46:57.5 9/1/2006: Creating Primary Surface - Windowed Mode
17:46:57.5 9/1/2006: Creating Back Buffer
17:46:57.5 9/1/2006: Loading graphic surfaces
17:46:57.5 9/1/2006: Creating Surfaces Misc and Dialogs
17:46:57.6 9/1/2006: Creating Surface Volume
17:46:57.6 9/1/2006: Creating Surfaces Arrows
17:46:57.6 9/1/2006: Creating Surfaces GameEXlogo Text
17:46:57.6 9/1/2006: Creating Surfaces Toolbar
17:46:57.7 9/1/2006: Creating Surfaces Backgrounds
17:46:57.7 9/1/2006: Creating Surfaces Toolbar Controls
17:46:57.8 9/1/2006: Creating Surfaces GameEx Logo
17:46:57.8 9/1/2006: Creating Surfaces Home & Exit
17:46:57.8 9/1/2006: Creating Surfaces Snaps
17:46:57.8 9/1/2006: Creating Surfaces Menu and List Bars
17:46:57.9 9/1/2006: Creating Fonts
17:46:57.9 9/1/2006: Creating Menu Font
17:46:58.0 9/1/2006: Creating Game Font
17:46:58.0 9/1/2006: Creating Font Black
17:46:58.1 9/1/2006: Creating Font Black Small
17:46:58.2 9/1/2006: Creating Game Font Faded
17:46:58.3 9/1/2006: Creating Title Font
17:46:58.3 9/1/2006: Restoring Title Font From Cache
17:46:58.4 9/1/2006: Fonts Created Succesfully
17:47:22.5 9/1/2006: Initialising Windows Media Player Component
17:47:22.5 9/1/2006: Loading Controls.ini map file
17:47:22.5 9/1/2006: MAME CMD options: -triplebuffer -nowindow -joy
17:47:22.5 9/1/2006: Attempting to load game list
17:47:22.6 9/1/2006: Loading last used Game List
17:47:22.6 9/1/2006: Loading Start Page
17:47:22.7 9/1/2006: Setting Music Volume
17:47:22.7 9/1/2006: Creating DirectSound Device
17:47:22.7 9/1/2006: Trying: Primary Sound Driver
17:47:22.7 9/1/2006: Loading Sound Files
17:47:22.8 9/1/2006: DirectSound Device Created Successfully
17:47:22.8 9/1/2006: Initialising DirectInput for Gamepad support
17:47:22.9 9/1/2006: Unable to create a joystick device
17:47:22.9 9/1/2006: Playing intro sound file
17:47:22.9 9/1/2006: Initializing MCE Remote
17:47:22.9 9/1/2006: Initialization OK! Starting GameEx!
17:47:22.9 9/1/2006: Testing Main Loop Once: Processing Frame
17:47:23.1 9/1/2006: ERRORS DETECTED: EXITING
17:47:23.1 9/1/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
17:47:23.1 9/1/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
17:47:23.1 9/1/2006: at GameEx.GameEx.mainform.DrawHorizMenu(Boolean drawfront)
17:47:23.1 9/1/2006: at GameEx.GameEx.mainform.DisplayFrame()
ok, so i tried three different resolutions, both with GameEx set to change the screen resolution and not to change the resolution. no luck.
if i have GameEx default to the primary monitor it does the same thing, unless MCE is also running on the primary monitor, in which case it seems to function fine.
i almost wonder if there's a problem with the splash screen, which seems to be forced onto the primary display...?
i know that purchasing the program will get rid of the splash screen, which i will do, but i want to know that the program is going to do what i need it to before i spend money on it.
if it isn't the splash screen, then i don't have a clue what could be the issue...
The splash screen is still there in the registered version, it just only shows for a second. I cant troubleshoot your problem, as I dont have this kind of setup. I do know that someone else had this problem a couple of months back, and there was a thread detailing how to get GameEx to do this, I think with MultiMon.
Please try and find that post. As I said I cant help any further with this, as Im not able to duplicate the scenario, but it sounds like theres a bug somewhere in GameEx that I need to fix.
