i hooked my pc to my 27" tv through my graphicx card s-video to rca plugs. everything works stellar, but when i try to launch a chankast game, it opens it in a window sized correctly, but not full screen. also a message pops up saying i'm trying to open a .bin file. this doesn't happen when i us my pc monitor, what could be causing this?!
Your probably trying to run chankast at a resolution the TV can't handle. Try lowering it to 1024x768 or more probably 800x600. I will assume your using the latest version of chankast, otherwise you need the -forcefull option.
You might also have to force set your refresh rate to 60hz for TV out. I had to do that with a lot of my emulators or the screen would flicker and sometimes go blank because it couldn't sync. But it looks like you alrady got it fixed, so NEVERMIND! :)
