NES, GBA, and Neo-Geo Pocket ini's???
Can anyone help me configure neo-geo pocket, GBA, and NES into gameex. I browsed the user submitted configs, and only found text docs, and I have no clue how to convert them into .ini's.
use the config app there is no need to manualy edit the ini file
Welcome
The text docs are portions of the GameEx\CONFIG\GameEx.ini file.
I think most people edit the GameEx.ini directly although you can import configurations into the GameEx config app. Emulators section via Import Emulator. It's looking for one of those text files.
To edit the INI directly:
Open up that file in notepad or something and search for "[Emulator_1]"
The lines between [Emulator_1] and [Emulator_2] represents an emulator configuration. The text docs you mentioned are the substitutions for these sections. You normally just replace the entire section (between [Emulator_1] and [Emulator_2] for instance) with the text file.
Once you've made the wholesale change, you can use the GameEx config app to change individual elements to suit your configuration without further manual editting of the ini file.
You'll still need to install the various emulators and get them working of course... :)
If you're new to this type of thing, BACKUP your GameEx.ini FIRST!...
Shaun
Hey Tom, This guy is the 1000th Forum member! Does he get a prize or something!!!???
