Hi guys,
I seriously need help configuring the controller.cfg file to make it work for Zinc in Gameex.
I have done this:
Have pointed to the the render and control files in Gameex. Also pointed to Zinc folder and Zinc.exe. My Zinc.exe is not located under C: but have tested it also. Same problem.
Have pointed the roms in the MAME roms path so this I get:
When I start GameEx I see the Playstation option with all Zinc games under it and also the Zinc games are under MAME. So far so good. I can start a game (the render is fine) BUT the controls don't seem to work even if I edit the Control.cfg and the file for X-Arcade. (I have a X-Arcade controller)
I use Dafreaks Zinc GUI. Some people say that you must use the other GUI available (don't remember the name) to edit the controlls and launch from Dafreaks Zinc GUI.
Also I have a problem with Vivanonno (Ridge Racer 2 and Rave Racer) Can manage to map the controls to the X-Arcade controller. Anyone knows how?
Please help because those two problems are last things I have to solve before it's complete.
I use ZINCFE to launch zinc
Its also lets me remap the keys
What I do it run ZINCFE and remap keys and buttons
*you need to get WinterBlasts zinc controller file...I forget why but I remeber this was something that fixed a ton of problems
Now once you get keys remapped and ZINCFE plays the games as expected - exit zinfe
Now it should work in Gameex
FYI - for some reason the controls would revert back (or to something else)
I set all al files in ZINC directory that began with CONTROLLER*.* to read-only
This kept my keys from changing
Thank you very much TX_TRINITY and Atari800. It finally worked. Now the only thing left is to map the controls in the System 22 Emulator Vivanonno to my X-Arcade controller.
