Hi, been using PBX for a long time now. My problem started almost a year ago.
Suddenly DMD started to disappear from my tables, I quickly found out that it got sent outside my screens (xpos=5123 ypos=3187).
My setup looks like:
1: 42" 1920x1080 Playfield
2: 15" 1280x1024 DMD
3: 27" 1920x1080 Backglass
I can reset DMD back to where I want it and play through VPX directly without any problems. But as soon as I start the table with PBX the DMD shows up for a split second, then jumps away to those x and y again.
I've done clean install of Windows and everything but nothing has helped.
Think I've done everything that can be done.
Will post my ini-files tomorrow.
Thanx.
Please be aware that your thread had to be moved from the GameEx>General forums! Please be careful where you post so you can ensure a reasonable response.
Please attach (no copy & paste please) copies of your pinballx.ini and your log.txt files - both are needed to begin to triage your issues with your setup.
