hey, i've made a shortcut to chankast-launch for each of my games after configuring chankast-launch to my drive letter, and notifying that i am using
hey, i've made a shortcut to chankast-launch for each of my games after configuring chankast-launch to my drive letter, and notifying that i am using alcohol. inside the target box of the created .lnk game file, i've typed something like this
C:\Dreamcast\chankast-launch.exe -screen 1280x1024 -fullscreen -cpu 108 -showstats -axcmd "C:\Program Files\Alcohol Soft\Alcohol 120\axcmd.exe" 0 "C:\Dremacst\Games\Power Stone.mdf"
the game ex front end i am using is all set and configured, and upon launching in debug mode, it says echo is ON, PAUSE press any key, then after that is a warning sound from windows, and it returns me to the front end. I'm sure i've typed the wrong thing somewhere, or just confused the command text a bit, if someone can guide me through this one, it'd be highly appreciated.
Just checking, did you do a a cut-and-paste on the command line above? The final directory entry is mis-spelled!
Shaun
Shaun
ok, i got rid of alcohol, got daemon 4.0.3 and my shortcut target box is as follows
C:\Dreamcast\chankast_launch.exe -delay 10 -screen 1280x1024 -fullscreen -cpu 108 -showstats -daemon "C:\Program Files\Daemon Tools\daemon.exe" 0 "C:\Dreamcast\Games\Power Stone.mds"
it mounts the image, and opens chankast, but not running the game, nor in fullscreen.
Ok, i think i might know where the problem is; chankast hasn't been told which drive to use;
i've changed your command to what i think might work:
C:\Dreamcast\chankast_launch.exe -exit -drive g -delay 10 -fullscreen -screen 1280x1024 -cpu 108 -showstats -daemon "C:\Program Files\Daemon Tools\daemon.exe" 0 "C:\Dreamcast\Games\Power Stone.mds"
You need to change the blue letter to suit the drive letter you are mounting to (0) in this case
damn, i was feeling good about that. what happens now, is the same thing, only 'sometimes' windows opens up the contents of my virtual drive "F:" device 0, in other words, as if you opened power stone in windows, all those files pop up in a F: window.
hmm it was my understanding that Chankast only used CDI images...if it was any other format it would fail.
well, it runs if i mount the .mds and click start, and i've tried that config above with zer-mvc2.cdi and it still won't work
Well I'll look into this more after I get issues resolved with ScummVM...as thats my current task.
what problems are you having with scummvm, and where abouts are you?
