Hi Tom,
I'm italian and sorry for my googlenglish :lol:
I upgrade Gameex from 6.57 and i found this problems :
1) when I install the new version of gameex the language is not more custom and I must re-select it in the setup, this is normal?
2) I have translate "trackball games" as the others in gameex.ini but it remain in English
3) All the letters with accents come cancelled with new gameex installation
4) when one passes from the fullscreen to the window-mode the titles them of the shielded ones are corrupts and strange :
Fullscreen mode
Windows mode
thank you for support and for gameex...it's a super frontend
:P
5) Sega Model2 v.0.3 games do not go more automatically.
To the start of a game must use the mouse in order to activate the list of the games, fact this it work.
n.b. with model2 old version no problem.
6) Some images have artefacts, red lines and pixels on console, in proximity of the red line of my theme 1024x768, this did not happen with gameex 6.57
now with 6.71 only 4) is ok
tom are you here ? I begin to feel itself single :unsure:
I was having all the same problems as mentioned in this post. Using the GameeX game launcher or even the old Au3 game launch way , I never could get the Model 2 emulator to auto launch any of the games. I would be left with an Autolaunch icon in the system tray , with a pause script message.
Finnaly I made headway. I noticed that the scripts the autolauncher uses includes the ALT key to open the top menu "Emulator".. The same exact way the ALT key highlights the file menu in a normal windows folder/app/program. Example: If I hit ALT now it will Highlight the File menu at the top of this page , i can scroll to Edit,View,Favorites,ETC.. by pressing left , ENTER opens the submenus.
In my version of the Model2 , which is the latest version from the nebula homepage. I cannot get the ALT key or any key for that matter to open the EMULATOR menu , i.e File etc..
I had to use the old Au3 Autolauncher program that was provided in earlier Model 2 posts from I think H8sh8. This of course is no new news and I am sorry for embelishing, If this ALT problem does seem to be your dead end , just play around with opening the Emulator menu with Auto Mouse Clicks rather that an Auto ALT key Press. If u still need help and u think that your problem is the ALT key problem , u can can get in touch with me and I can send u the Au3 files I have edited to work with mouse clicks rather than ALT presses. I have searched the forums for an answer and am not sure if this hasnt been addressed somewhere else, Please let me kno if this has alrdy been clrd up with an easier way .
