Hi,
I have a little problem with two Pinballs in PinballX. I use only VPX tables. In - for example Masters of the Universe - I have in VPX a Backglass, if I start with Pinball x I get for the Backglass an error.
Why? What do I wrong?
The first thing you did wrong was not provide enough information when reporting an error) ;). What you need to do is:
1. Attach copies of your pinballx.ini and log.txt files
2. Attach a copy of your Visual Pinball.xml file
3. List all of the table names that you are experiencing the issue
4. The error message you are seeing or attach a screen capture of the error
