Can't Create group for pinball fx 3 tables using game manager but did work if i create xml myselve
Hello,
I have 6 systems currently "Pinball FX2" (<- is disabled), "Pinball FX3", "Visual pinball", "Visual Pinball X", "Zaccaria pinball" and "Future Pinball". I basically wanted to create a group to view the tables per emulator / system. if i goto game manager and select create new group i don't see "Pinball FX3\Pinball FX3" in the "select lists" "combobox" i do see all the other (enabled) list but not the FX3 one.
So i created a group xml myselve containing only the following to link a single xml file (containing my complete list of pinball FX3 tables) so i get a list with only pinball fx3 tables.
Quote
<group name="Zen Pinball FX3">
    <database>Pinball FX3\Pinball FX3</database>
</group>
 this did work and i can see and use the list inside pinballx and can also "view" it in groups manager but i was not able to create such file using gamemanager only. I basically repeated this step to create a group with 1 link to a database file for each (full) game list i have per system so i get a list for each emulator / system (manually did not use game manager)
I'm not sure if i got something wrong setup somehow or if it might be a little bug somewhere so i included my settings files in the attachments below.
I'm using PinballX 3.2.9 at least according to the pinballx settings tool, which i think is the latest version
Zen Pinball FX3.xml (group file i created myselve) From Databases\Groups
Pinball FX3.xml (pinball fx3 database file) From Databases\Pinball FX3
PinballX.ini (main settings file)
i'm not sure these will help but prodived them anyway
[SETTINGS].log
all my database files: Databases.zip
