6.61 Gameex...wont start..need help or 6.60 version
12:27:58.1 8/25/2006: GameEx: Version 6.61: Starting Log
12:27:58.1 8/25/2006: Operating System Platform: Win32NT
12:27:58.1 8/25/2006: Operating System Name: Windows Server 2003
12:27:58.1 8/25/2006: Operating System Version: 5.2.3790
12:27:58.1 8/25/2006: Checking for versions of .net Framework installed
12:27:58.1 8/25/2006: .net Framework 1.1 Installed
12:27:58.1 8/25/2006: .net Framework 2.0 Installed
12:27:58.1 8/25/2006: Running Randomize()
12:27:58.1 8/25/2006: Checking for applications to Launch On Startup
12:27:58.1 8/25/2006: Initialising Video/MNG DLL's
12:27:58.1 8/25/2006: Running Misc startup tasks
12:27:58.1 8/25/2006: Setting Menu types
12:27:58.1 8/25/2006: Opening Configuration File
12:27:58.1 8/25/2006: Getting Configuration Values
12:27:58.1 8/25/2006: Using Theme: Default - GameEx
12:27:58.1 8/25/2006: Checking for alternate Image Directory for Theme: Default - GameEx
12:27:58.1 8/25/2006: Launching HideOS.exe
12:27:58.1 8/25/2006: Hiding Taskbar
12:27:58.2 8/25/2006: Is Media Center running?
12:27:58.2 8/25/2006: Checking/Creating LCD Registry values
12:27:58.2 8/25/2006: Check Media Center Exit/Start Mode
12:27:58.2 8/25/2006: Media Center Mode 2
12:27:58.2 8/25/2006: Text/Language: English
12:27:58.2 8/25/2006: Applying Language/Text
12:27:58.2 8/25/2006: Custom Keyboard Input enabled: Getting custom codes
12:27:58.2 8/25/2006: Snap Delay set to: 6
12:27:58.2 8/25/2006: Get other settings
12:27:58.3 8/25/2006: Set: Find emulator artwork on best match basis
12:27:58.3 8/25/2006: SlikStik support enabled
12:27:58.3 8/25/2006: Using DirectInput for keyboard input
12:27:58.3 8/25/2006: Start work for Form
12:27:58.3 8/25/2006: Getting Original Screen Size
12:27:58.3 8/25/2006: Loading ICON
12:27:58.3 8/25/2006: Initializing Component
12:27:58.3 8/25/2006: Initialising Bass Audio Library
12:27:58.4 8/25/2006: Loading default loading screen
12:27:58.5 8/25/2006: Using 2D Animations
12:27:58.5 8/25/2006: Using General Font: HandelGothic BT
12:27:58.5 8/25/2006: Using Title Font: HandelGothic BT
12:27:58.5 8/25/2006: Initialising DirectDraw
12:27:58.5 8/25/2006: Creating DirectDraw Device
12:27:58.5 8/25/2006: Using Device: NVIDIA GeForce 6200
12:27:58.5 8/25/2006: Setting Resolution to 1024x768 32 bit color
12:27:58.5 8/25/2006: Creating DirectDraw Surfaces
12:27:58.5 8/25/2006: Creating Primary Surface - Full Screen Mode
12:27:58.5 8/25/2006: Creating Back Buffer
12:27:58.5 8/25/2006: Loading graphic surfaces
12:27:58.6 8/25/2006: Creating Surfaces Misc and Dialogs
12:27:58.6 8/25/2006: Creating Surface Volume
12:27:58.6 8/25/2006: Creating Surfaces Arrows
12:27:58.6 8/25/2006: Creating Surfaces GameEXlogo Text
12:27:58.6 8/25/2006: Creating Surfaces Toolbar
12:27:58.7 8/25/2006: Creating Surfaces Backgrounds
12:27:58.7 8/25/2006: Error: 91 - Object reference not set to an instance of an object.
12:28:00.7 8/25/2006: ERRORS DETECTED: EXITING
