finally for those who likes this baby there is an update ...
here is a distription :
After more than 2 years without updates here is a new version of my Model 2 Emulator. The main changes are all speed related. The emu should be faster now. Also it now supports Frameskip and AutoFrameskip. This will probably be the last version of the emulator unless some Fujitsu TGP MB86234 docs appear to finish the emulation of the 2 and 2A cores.
http://nebula.emulatronia.com/
hi all,after i updated the m2 emu I just get a blank screen in gameEX?
it works fine out of gameEX?
just thought I would let you no.
Thanks,
Leon.
Anyone know if this is an update issue? I'd love faster M2 emulation but I'm afraid to update and end up like the guy who posted ahead of me. :)
i guess there might be some changes there might make the emulator not compatible with GameEx thats why i made the tread so people could try and if its an issue from GameEx side then Tom Can look into it :)
anyway the emulator works fine here outside GameEx as well havent put it in GameEx yet...
I have posted issues I was having with the v0.3 release of Model2 in the Model 2 error topics. My main problem started when I had to switch to a rewrite I did of the Au3 files as opposed to being able to use the GameEx advance Mame options. This is due to a problem I found in V0.3 .. There is no ALT support to bring up emu menus , file etc..
This of course makes the Autolauncher useless,
So after doing my own rewrite of the Au3 files I thought i was doing fine, .. I then found that the gun Games do not support the aiming reticle in Full screen mode in V0.3
I have run trests with this , and I have also looked for any other topics like this one in the forums , but due to the weird search errors I get , (such as the search hitting no matches with keywords like Model , 2, but single words like Model2 net hits.. weird) I had to switch back to V0.1 and theres seems to be none of these problems. Also to the fact the author of the model2 seems to be retiring his work with this emu , I wonder if addressing any of these issues with him would be in vain.
If anyone is also having the same problems with these issues , its probally best to switch or find a version 0.1 alpha of the model2 to go with the GameEx frontend. 0.2 was unpublished so it is not on the net.
( I also have some posts on how u can get compatabilty with v0.3 and gameEx in the model2 error topics, but it still will not display an aiming reticle in the Fullscreen mode.)
