Hi.   I have a PC working fine with GroovyMame and switchres.  However,  when I use Gameex it doesn't work... gameex fades out for a moment then fades back.   When I use cmd Groovymame works fine.   I'm simply pointing gameex to the exe and the roms.  I don't use special command lines in setup wizard and I don't change anything in ArcadeVGA or force a resolution in Gameex. Is there something special that must be done when using groovymame?
Yes, thank you.
EDIT: It appears that I turned on using advancemame in my GameEx.ini file.  It doesn't appear it the setup wizard so i overlooked it.  By turning off using AdvanceMame (I was using it to open RocketLauncher) everything "Just Works" now!  Thank you Tom for being a sounding board for my small hurdle. :)
GameEx.ini
Edited by Black Mage
