Yep I got more :) So I have my DOA stick using mame, and have remapped all my buttons except 1 the esc key. I still have to get the keyboard out to use it when I'm playing a game. I didn't see anywhere to change it in mame I could be just missing it. I'd like to setup a button for it, tab, and pause if I could.
Also I know the answer is probably no to this one, but in games that have bezels on them for example most of the street fighters, is there anyway to remove them and have the game take up the entire screen? I figured it was just part of the game and nothing could be done but it doesn't hurt to ask.
This if for you first question:
In MAME press [TAB]:
Go to:
[input general]
[user Interface]
"UI Cancel" -> Map this to the button or combination of buttons to exit from MAME.
Emph
Go to:
[input general]
[user Interface]
Emph
Thanks I totally skipped over the user intereface section
