Does anyone use this type of box? I am using this PC to TV box and output to S-Video. The problem I am having is that some of the Mame games the screen is scrambled.
Does anyone know what might cause this?
THANKS!
Chris
It's probably your resolution (or what MAME sets the resolution to)
I had a similar device and it would only "broadcast" 640x480 & 720x480
anything above that would scramble the TV
There are some devices that allow greater resolution
You could set MAME use a default resolution - worth a shot
