After finally finishing my new cocktail cabinet i decided it was time to sort Gameex out. so i fired it , worked ok was a bit laggy and found most of my emulators were missing so started about the task of getting them all back it ( obviously running out side of gameex 1st ) then transferring over 1 by one after several days of intense sorting.....i fired up gameex and it said update needed, so after getting stuck in the update loop i decided to download and do an over install as you do...... done
Fired  up gameex.... OMG !
Now game ex is completely screwed up...see inclosed photos 1st all menu is screwed up (1) and no controls work so i have to alt ctrl delete and see gameex is is not responding (2)..i kill it and then all my desktop is screwed up...missing all icons etc (3)... i have to log off and back on and then do a screen personalise to get it back..please help as i'm completely at a loss where to start, before the update everything worked ok, so if its an update that's caused it i'm screwed?.Just tried again see (4) even worse !!!
included config and log below...
gameex.ini
  • simbamame changed the title to [ RESOLVED ] Please Help an oldie
OK so after a lot of playing and tinkering, i believe i have sorted this problem, it appears to simply be a themes / change view problem. Why some themes and views screw it up ive no idea.
  • Draco1962 changed the title to [RESOLVED] Please Help an oldie
  • Draco1962 locked this topic
