Hello,
I'm trying to create snaps of Future Pinball.  I've tried all available "get snaps" 10sec, 20 sec. press esc... etc.   I only get a pic of my desktop with the Future Pinball program, not the table or backglass I'm seeing on the monitor.
What could I be missing?
Thanks!
I would try with another program, like MAME, and see if you get the same results. It may be a limitation with some programs to get snaps with GameEx. Personally, I would look about via Google as there are quite a bit of media available for various tables for the virtual pins.
Hi.
The create snaps feature is a bit depreciated now with modern versions of Windows because it's not possible to capture images from directx applications. It's normal behaviour. Sorry.
