Hi, I have a big problem with Gamex since the update i've done after the 6.17 version. When I start Gameex (standalone and through MCE), it freeze at the menu and I cannot use it. The menu is totally freezed.
To fix it, i tried to update it many time but the problem still remains again and again.
I also tried to delete all the games data using the configuration application (ADMIN/DELETE) but nothing changed.
FYI, when I starts the Windows task manager, I see the Gameex process is still running but stay at this step (Gameex line shows in task manager) :
GameEx|Demarrage|Most Played|0/60|
Whe I press CTRL/ALT/DEL to call the task manager, the numbers after most played is not "0/60" but "any value/60" (the most is seen is 50) and decrease to stay at "0/60"
To quit GameEx, I must kill it using the task manager.
The version I'm currectly using is the last one (6.47).
The GameEx computer is an Windows XP MCE 2005 with an AMD Athlon XP2400+, 1GB of Ram and an ATI Radeon All in Wonder 9800 pro 128MB (With the 6.6 catalyst AIW MCE)
Please, find hereafter the log file (note, the log file is complete and includes the truncated end line) :
13:16:39.8  13/07/2006:  GameEx: Version 6.47: Starting Log
13:16:39.8 13/07/2006: Operating System Platform: Win32NT
13:16:39.8 13/07/2006: Operating System Name: Windows XP
13:16:39.8 13/07/2006: Operating System Version: 5.1.2600
13:16:39.8 13/07/2006: Checking for versions of .net Framework installed
13:16:39.8 13/07/2006: .net Framework 1.0 Installed
13:16:39.8 13/07/2006: .net Framework 1.1 Installed
13:16:39.8 13/07/2006: .net Framework 2.0 Installed
13:16:39.8 13/07/2006: Checking Registration
13:16:39.8 13/07/2006: Running Randomize()
13:16:39.8 13/07/2006: Checking for applications to Launch On Startup
13:16:39.8 13/07/2006: Initialising Video/MNG DLL's
13:16:39.8 13/07/2006: Running Misc startup tasks
13:16:39.8 13/07/2006: Setting Menu types
13:16:39.8 13/07/2006: Opening Configuration File
13:16:39.8 13/07/2006: Getting Configuration Values
13:16:39.8 13/07/2006: Using Theme: Default - BlueEx - Arcade800x600
13:16:39.8 13/07/2006: Checking for alternate Image Directory for Theme: Default - BlueEx - Arcade800x600
13:16:39.8 13/07/2006: Arcade Mode is on
13:16:39.8 13/07/2006: Launching HideOS.exe
13:16:40.7 13/07/2006: Hiding Taskbar
13:16:40.7 13/07/2006: Is Media Center running?
13:16:40.8 13/07/2006: Checking/Creating LCD Registry values
13:16:40.8 13/07/2006: Check Media Center Exit/Start Mode
13:16:40.8 13/07/2006: Media Center Mode 2
13:16:40.8 13/07/2006: Text/Language: French
13:16:40.8 13/07/2006: Applying Language/Text
13:16:40.8 13/07/2006: Snap Delay set to: 1
13:16:40.8 13/07/2006: Get other settings
13:16:40.9 13/07/2006: Set: Find emulator artwork on best match basis
13:16:40.9 13/07/2006: SlikStik support enabled
13:16:40.9 13/07/2006: Using DirectInput for keyboard input
13:16:40.9 13/07/2006: Start work for Form
13:16:40.9 13/07/2006: Getting Original Screen Size
13:16:40.9 13/07/2006: Loading ICON
13:16:40.9 13/07/2006: Initializing Component
13:16:40.9 13/07/2006: Initialising Bass Audio Library
13:16:41.2 13/07/2006: Loading default loading screen
13:16:41.2 13/07/2006: Using 3D Alpha Blended Animations. This could be slow
13:16:41.2 13/07/2006: Using General Font: Trebuchet MS
13:16:41.2 13/07/2006: Using Title Font: Joystix
13:16:41.2 13/07/2006: Starting GameExtender Publisher
13:16:41.2 13/07/2006: Initialising DirectDraw
13:16:41.2 13/07/2006: Applying GameEx is Loading Image
13:16:41.3 13/07/2006: Creating DirectDraw Device
13:16:41.3 13/07/2006: Using Device: ALL-IN-WONDER 9800 SERIES
13:16:41.5 13/07/2006: Setting Resolution to 800x600 32 bit color
13:16:41.5 13/07/2006: Creating DirectDraw Surfaces
13:16:41.5 13/07/2006: Creating Primary Surface - Full Screen Mode
13:16:41.6 13/07/2006: Creating Back Buffer
13:16:41.6 13/07/2006: Loading graphic surfaces
13:16:41.7 13/07/2006: Creating Surfaces Misc and Dialogs
13:16:41.7 13/07/2006: Creating Surface Volume
13:16:41.7 13/07/2006: Creating Surfaces Arrows
13:16:41.7 13/07/2006: Creating Surfaces GameEXlogo Text
13:16:41.7 13/07/2006: Creating Surfaces Toolbar
13:16:41.8 13/07/2006: Creating Surfaces Backgrounds
13:16:42.2 13/07/2006: Creating Surfaces Toolbar Controls
13:16:42.2 13/07/2006: Creating Surfaces GameEx Logo
13:16:42.2 13/07/2006: Creating Surfaces Home & Exit
13:16:42.2 13/07/2006: Creating Surfaces Snaps
13:16:42.2 13/07/2006: Creating Surfaces Menu and List Bars
13:16:42.3 13/07/2006: Creating Fonts
13:16:42.3 13/07/2006: Creating Menu Font
13:16:42.4 13/07/2006: Creating Game Font
13:16:42.5 13/07/2006: Creating Game Font Standard Size
13:16:43.3 13/07/2006: Creating Font Black
13:16:43.5 13/07/2006: Creating Font Black Small
13:16:43.6 13/07/2006: Creating Game Font Faded
13:16:43.7 13/07/2006: Creating Title Font
13:16:44.2 13/07/2006: Creating Control Panel Font
13:16:44.9 13/07/2006: Fonts Created Succesfully
13:16:44.9 13/07/2006: Loading Controls.ini map file
13:16:44.9 13/07/2006: Loading Cust
PS: I'm using a registered version. My wife has bought a key for me ;)
Hi, can you think of anything else that has been changed on your system? New drivers, new software, personal firewall, anti virus/anti spyware or anything like that?
In addition, try turning off GameExtender publisher. Does it work if you disable your network connection temporarily. Does it work if you turn off the Slikstik support? What happens when you run GameEx in a window?
Has to be some kind of conflict going on.
Is it possible that there is something wrong in the GameEx.ini file ?
I tried all you said but nothing changed. So, I have renamed the GameEx.default.ini file to GameEx.ini and tried to start GE. With the default configuration file, it is working fine.
If it's due to my GameEx.ini file is wrong, is it a solution to fix it with to configure again GE ? I don't want loose many hours to do it.
Thanx
Thanx
Post the ini and Ill take a look.
I've just released a new version of GameEx, that should now not truncate the log.
I'm not pushing it out as an auto update just yet, so please download it from the site.
Try out your old ini, and post the log with 6.48
Hi Tom,
Sorry for the late answer, I was not at home the las week.
Just a good news ... since I have installed the last version (6.49) of GameEx, everything is working fine. I tried to launch it with my old ini file !!!
It seems that you have fixed a bug.
Thanx a lot
Indus
