Just working on my first cabinet and getting GameEx going. I can't seem to get the Ingame CP viewer to work. I'm not quite sure I how to set it up and use it.
Thanks,
Dan
Make sure that you have your ingameCP mapped to a key you have on your control cabinet. The default key GameEx configures is the letter 'K'. So, unless you change this, you'll have to map a button to the letter 'K' to use it. If not, you'll have to use a different code from the VKCodelist found in your GameEx folder:
"C:\Program Files\GameEx\CONFIG\EMULATORS\VKCodes.htm"
Right now my computer is still on my desktop, so I have a full keyboard. My default in GameEx is mapped to 76 which shows the "L" key. I've started MAME and hit the L key and nothing happens. Am I missing something?
If the "L" key is already mapped to something in Mame, I'm not sure if it will work. Press [TAB] while in Mame and check your key mappings.
I did see the L key mapped to something else. I changed it to 19 which shouldl be caps lock. Still no luck. Argh!
Any other ideas.
