Hi!!
Trying to configure Magic Engine 1.1.3 to launch CD games in GameEX with no luck by the moment...
I've readed lot of threads about this in the forum, but none have the solution for me.
I've configured command line for this emulator with: pce.exe -cd:E [DTLOADER]
Virtual Drive Loader is configured with: -mount dt, E, "[RomFullPath]" and -unmount_all command lines.
When launch a game, Magic Engine opens but game is not loaded. I have't a physical cd drive, only a virtual drive with E: letter. I've changed the default drive letter on magic engine configuration file with E:.
I've daemon tools lite 10.5 version.
Any sugestions to try?
Thanks in advance.
GameEx.ini
Magic Engine is a licensed product, therefore you must pay for the license to use it. It is worth it IMO.
i did grow up in that era though, so to ME, it is so worth it.
Hi Dazzle,
I solved the problem with command [DTLOADER-SCSI], it was the problem for not mounting on correct drive.
Thanks.
