Hi guys is anyone else having problems with the Dvds and Dvd on disk function working, it did work before and now even with 6.42 upgrade manually it still doesn't. I do have a registered version so no problem there.
Any ideas please?
Thx...Demon :D
Any ideas please?
Thx...Demon :D
hmm. Should have been fixed in 6.42 (released Yesterday). Can you confirm your deffinitly running that version, and also what OS your running.
Thanks,
Tom.
Yes tom i'm running latest version 6.42 manual download and install upgrade, and running windows xp media centre edition 2005.
The dvd on disk work in mediaplayer but not in gamex, yet they did.
Thx for the reply....Demon :D
Can you post the log, also try the VMR 9 setting under Multimedia settings.
Also what video card do you have and what DVD software are you using?
Thanks,
Tom.
Thanks,
Tom.
Bump. Please help me get this fixed.
Thanks,
Tom
  • 4 weeks later...
Bump again. Anyone else having issues with DVD's since recent versions? Its all working fine for me.
Yes Tom:
I am also having issues with the latest release tried all the codecs as well and options. This used to work just fine awhile back and recently started to use again. I have an arcade VGA card, 16 640 X 480. System goes to start DVD see a black background kind of screen flash and then it returns to the main select list.
00:03:02.3 7/31/2006: GameEx: Version 6.51: Starting Log
00:03:02.3 7/31/2006: Operating System Platform: Win32NT
00:03:02.4 7/31/2006: Operating System Name: Windows XP
00:03:02.4 7/31/2006: Operating System Version: 5.1.2600
00:03:02.4 7/31/2006: Checking for versions of .net Framework installed
00:03:02.4 7/31/2006: .net Framework 1.0 Installed
00:03:02.4 7/31/2006: .net Framework 1.1 Installed
00:03:02.4 7/31/2006: .net Framework 2.0 Installed
00:03:02.5 7/31/2006: Checking Registration
00:03:02.5 7/31/2006: Running Randomize()
00:03:02.5 7/31/2006: Checking for applications to Launch On Startup
00:03:02.6 7/31/2006: Initialising Video/MNG DLL's
00:03:02.6 7/31/2006: Running Misc startup tasks
00:03:02.6 7/31/2006: Setting Menu types
00:03:02.6 7/31/2006: Opening Configuration File
00:03:02.6 7/31/2006: Getting Configuration Values
00:03:02.8 7/31/2006: Using Theme: Default - Tron
00:03:02.8 7/31/2006: Checking for alternate Image Directory for Theme: Default - Tron
00:03:03.1 7/31/2006: Launching HideOS.exe
00:03:03.1 7/31/2006: Hiding Taskbar
00:03:03.5 7/31/2006: Is Media Center running?
00:03:03.5 7/31/2006: Checking/Creating LCD Registry values
00:03:03.5 7/31/2006: Check Media Center Exit/Start Mode
00:03:03.5 7/31/2006: Media Center Mode 0
00:03:03.7 7/31/2006: Text/Language: English
00:03:03.7 7/31/2006: Applying Language/Text
00:03:04.5 7/31/2006: Snap Delay set to: 6
00:03:04.5 7/31/2006: Get other settings
00:03:04.7 7/31/2006: Desktop set to Hide ICONS and set Background to Black
00:03:04.7 7/31/2006: Backing up Registry Wallpaper Settings
00:03:06.1 7/31/2006: Set: Find emulator artwork on best match basis
00:03:06.1 7/31/2006: SlikStik support enabled
00:03:06.1 7/31/2006: Using DirectInput for keyboard input
00:03:06.1 7/31/2006: Start work for Form
00:03:06.1 7/31/2006: Getting Original Screen Size
00:03:06.1 7/31/2006: Loading ICON
00:03:06.1 7/31/2006: Initializing Component
00:03:06.3 7/31/2006: Initialising Bass Audio Library
00:03:06.7 7/31/2006: Loading default loading screen
00:03:06.8 7/31/2006: Using 2D Animations
00:03:06.8 7/31/2006: Using General Font: Trebuchet MS
00:03:06.8 7/31/2006: Using Title Font: Trebuchet MS
00:03:06.8 7/31/2006: Starting GameExtender on:
00:03:06.8 7/31/2006: Initialising DirectDraw
00:03:07.0 7/31/2006: Creating DirectDraw Device
00:03:07.2 7/31/2006: Setting Resolution to 640x480 16 bit color
00:03:07.3 7/31/2006: Cannot Set Resolution
00:03:07.3 7/31/2006: Trying current windows resolution
00:03:07.3 7/31/2006: Creating DirectDraw Surfaces
00:03:07.3 7/31/2006: Creating Primary Surface - Full Screen Mode
00:03:07.3 7/31/2006: Creating Back Buffer
00:03:07.5 7/31/2006: Loading graphic surfaces
00:03:07.6 7/31/2006: Creating Surfaces Misc and Dialogs
00:03:07.7 7/31/2006: Creating Surface Volume
00:03:07.8 7/31/2006: Creating Surfaces Arrows
00:03:07.8 7/31/2006: Creating Surfaces GameEXlogo Text
00:03:07.8 7/31/2006: Creating Surfaces Toolbar
00:03:07.9 7/31/2006: Creating Surfaces Backgrounds
00:03:11.8 7/31/2006: Creating Surfaces Toolbar Controls
00:03:11.9 7/31/2006: Creating Surfaces GameEx Logo
00:03:11.9 7/31/2006: Creating Surfaces Home & Exit
00:03:11.9 7/31/2006: Creating Surfaces Snaps
00:03:12.0 7/31/2006: Creating Surfaces Menu and List Bars
00:03:12.3 7/31/2006: Creating Fonts
00:03:12.3 7/31/2006: Creating Menu Font
00:03:13.5 7/31/2006: Creating Game Font
00:03:14.6 7/31/2006: Creating Font Black
00:03:14.7 7/31/2006: Creating Font Black Small
00:03:14.8 7/31/2006: Creating Game Font Faded
00:03:16.1 7/31/2006: Creating Title Font
00:03:19.4 7/31/2006: Creating Control Panel Font
00:03:20.2 7/31/2006: Fonts Created Succesfully
00:03:20.3 7/31/2006: Initialising Windows Media Player Component
00:03:20.7 7/31/2006: MAME Path is: D:\mame 1.00\Mame 100.4\Mame32
00:03:20.7 7/31/2006: daphne Path is: C:\Daphne
00:03:20.8 7/31/2006: daphne EXE file is: Daphne.exe
00:03:20.8 7/31/2006: Use daphne on. Daphne.exe will launch games
00:03:20.8 7/31/2006: Model 2 Path Path is: C:\Model2v0.1
00:03:20.8 7/31/2006: Model 2 EXE file is: emulator.exe
00:03:20.9 7/31/2006: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
00:03:20.9 7/31/2006: ZiNc Path is: C:\Zinc_v1.1
00:03:20.9 7/31/2006: ZiNc EXE file is: ZiNc.exe
00:03:20.9 7/31/2006: Use ZiNc on. ZiNc.exe will launch PSX games
00:03:21.0 7/31/2006: MAME EXE file is: Mame32.exe
00:03:21.0 7/31/2006: ROM Path is: D:\mame 1.00\Mame 100.4\Mame32\roms
00:03:21.0 7/31/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
00:03:21.1 7/31/2006: controls.ini is located at: D:\mame 1.00\Mame 100.4\Mame32\controls.ini
00:03:21.1 7/31/2006: History.dat is located at: D:\mame 1.00\Mame 100.4\Mame32\history.dat
00:03:21.1 7/31/2006: nplayers.ini is located at: D:\mame 1.00\Mame 100.4\Mame32\nplayers32.txt
00:03:21.1 7/31/2006: MAMEinfo.dat is located at: D:\mame 1.00\Mame 100.4\Mame32\mameinfo.dat
00:03:21.1 7/31/2006: Loading Controls.ini map file
00:03:21.2 7/31/2006: Loading Custom Emulators
00:03:21.2 7/31/2006: Loading Emulator 1: MAME MisFit
00:03:21.3 7/31/2006: Loading Emulator 2: Nintendo SNES
00:03:21.4 7/31/2006: Loading Emulator 4: Nintendo NES
00:03:21.5 7/31/2006: Loading Emulator 5: Atari 2600
00:03:21.7 7/31/2006: Loading Emulator 6: Coleco Vision
00:03:21.7 7/31/2006: Loading Emulator 7: Sega Genesis
00:03:21.8 7/31/2006: Loading Emulator 8: Intellivision Games
00:03:21.9 7/31/2006: Loading Emulator 9: Commodore 64
00:03:22.0 7/31/2006: Loading Emulator 10: Nintendo 64
00:03:22.1 7/31/2006: Loading OfflineList Dat File for emulator: 10
00:03:22.1 7/31/2006: Cannot Find Offline List Dat File
00:03:22.3 7/31/2006: Snap Path is: D:\mame 1.00\Mame 100.4\Mame32\snap
00:03:22.3 7/31/2006: AVI Snap Path is: D:\mame 1.00\Mame 100.4\Mame32\video
00:03:22.3 7/31/2006: Flyer Path is: D:\mame 1.00\Mame 100.4\Mame32\flyers
00:03:22.3 7/31/2006: Cabinet Path is: D:\mame 1.00\Mame 100.4\Mame32\cabinets
00:03:22.4 7/31/2006: Title Path is: D:\mame 1.00\Mame 100.4\Mame32\titles
00:03:22.4 7/31/2006: Panel Path is: D:\mame 1.00\Mame 100.4\Mame32\cpanel
00:03:22.4 7/31/2006: Icon Path is: D:\mame 1.00\Mame 100.4\Mame32\icons
00:03:22.4 7/31/2006: Marquee Path is: D:\mame 1.00\Mame 100.4\Mame32\marquees
00:03:22.4 7/31/2006: MAME CMD options: -nowindow -joy
00:03:22.4 7/31/2006: Attempting to load game list
00:03:22.8 7/31/2006: Loading last used Game List
00:03:22.8 7/31/2006: Loading Start Page
00:03:23.1 7/31/2006: Setting Music Volume
00:03:23.1 7/31/2006: Playing Station: http://www.977alt.com/977alt.asx
00:03:27.0 7/31/2006: Loading music
00:03:41.3 7/31/2006: Creating DirectSound Device
00:03:41.3 7/31/2006: Trying: Primary Sound Driver
00:03:41.3 7/31/2006: Loading Sound Files
00:03:41.6 7/31/2006: DirectSound Device Created Successfully
00:03:41.7 7/31/2006: Creating ICONS
00:03:41.7 7/31/2006: Restoring Cached ICONS from File
00:03:42.5 7/31/2006: Initialising DirectInput for Gamepad support
00:03:42.5 7/31/2006: Looking for Device: Adaptoid
00:03:42.9 7/31/2006: Device Created
00:03:43.0 7/31/2006: Initialising DirectInput for Keyboard support
00:03:43.1 7/31/2006: Playing Startup Video
00:03:43.9 7/31/2006: Playing intro sound file
00:03:43.9 7/31/2006: Initializing MCE Remote
00:03:43.9 7/31/2006: Initialization OK! Starting GameEx!
00:03:44.0 7/31/2006: Testing Main Loop Once: Processing Frame
00:04:19.9 7/31/2006: Exiting GameEx!
00:04:19.9 7/31/2006: Saving Settings
00:04:25.0 7/31/2006: Checking for applications to Launch On Exit
Yes Tom:
Thanks for posting. Could you tell me what DVD Codec/Software you are using and which version?
Also do you know if you have the Radeon 7 or 9 series ArcadeVGA card.
Thanks,
Tom.
Thanks,
Tom.
Tom:
Attached is the info on the video card:
In regard to the codec.. I am using WinDVD 4..if I have the wrong thing here let me know or where to find it..thanks
Tom:
I know it's a lot to ask but can you temporarily uninstall WinDVD4 and try out the "latest" evaluation version of PowerDVD or Nvidia DVD?
I think this problem is related to older versions of DVD software, and WinDVD 4 is really old software now. It's difficult to find a version of WinDVD that old, so I can't test and try to fix with it.
Thanks.
Tom
Thanks.
Tom
Tom:
Went to check it again before going through the uninstal, install routine...it worked with one of the latest two updates? Wierdest thing works fine now..it it bombs out again I will try updating the codec.
Thanks!
