Hiya Johnny. GameEx generally requires that a command line be utilized to launch most games via emulators.
Please be aware of where you post. I moved your post from the Convert-It support forum which isn't a good place to ask for assistance with GameEx.
The first thing you will want to do or confirm for us is that you are able to run the emulator outside of GameEx first. Next, you will want to setup the emulator in one of the available emulator slots. Depending on how your game files are compressed, you will need to input *.zip for your ROM filter and use the following command line Supermodel.exe "[ROMPATH]\[ROMFILE]" -res=800,600 -fullscreen . I do not use this emulator so don't hold me to it, but there are a few members here that will probably join in to assist.
You will probably want to refer to this post as an example as you will probably need some guidance when referencing the Map files to correct the file names. Good luck!
You are going to have to give us more details than that I'm afraid. Can't find anywhere to setup what within what application? Lite version of what? There is a Setup Wizard program within your \GameEx\ install path that you have to run. Sounds like you are trying to look for something after loading GameEx and that simply won't work.
Can you confirm that you have the emulator working properly outside of GameEx as previously instructed?
Last, you will have to open the Setup Wizard and input the necessary information in an available emulator slot in the Emulator Setup and Advanced Emulator Setup sections.
