Im trying to get Zinc to run with GameEx all is working now except I cannot get it to point to my controller config...
Im using winterblasts input addon and I used ZincFE to set up the controller buttons...once set I then made...
ZINC.CFG to add in GameEx Config so that It will launch all options with --use-config-file=zinc.cfg
With in Zinc.cfg I have....
;default setup
--sound-filter-enable=yes
--renderer=c:\zinc\d3d_renderer.znc
--controller=c:\zinc\pcfg\controller.znc
--use-controller-cfg-file=c:\zinc\pcfg\controller.cfg
nothing will work it just hangs then goes back to GameEx...if I run command line or with ZINCFe it works fine...
If I remove the line --use-controller-cfg-file=c:\zinc\pcfg\controller.cfg it loads but does not have my buttons set up....really frustrating does anyone know what I could be doing wrong?
And yes I noticed I spelled Zinc wrong in the topic whoops =P
I tried using a Zinc.cfg file and it didn't work for me either. I just specified the options in the GameEx configuration instead. I use this setup and it works fine for me:
For the GameEx configuration I use these options:
UseZinc=True
ZincEXE=ZiNc.exe
ZincPath=C:\Zinc
ZincOptions=--renderer=C:\Zinc\renderer.znc --use-renderer-cfg-file=C:\Zinc\renderer.cfg --controller=.\controller.znc --use-controller-cfg-file=.\controller.cfg
Here is my renderer.cfg file:
; ogl/d3d renderer settings
XSize = 640 ; Window/fullscreen X size
YSize = 480 ; Window/fullscreen Y size
FullScreen = 1 ; Fullscreen mode: 0/1
ColorDepth = 32 ; Fullscreen color depth: 16/32
ScanLines = 0 ; Scanlines: 0=none, 1=black, 2=bright
Filtering = 0 ; Texture filtering: 0-3 (filtering causes glitches!)
Blending = 1 ; Enhanced color blend: ogl: 0/1; D3D: 0-2
Dithering = 0 ; Dithering: 0/1 (only needed in 16 bit color depths)
ShowFPS = 0 ; FPS display on startup: 0/1
FrameLimitation = 1 ; Frame limit: 0/1
FrameSkipping = 0 ; Frame skip: 0/1
FramerateDetection = 1 ; Auto framerate detection: 0/1
FramerateManual = 100 ; Manual framerate: 0-1000
TextureType = 3 ; Textures: 0=card's default, 1=4 bit, 2=5bit, 3=8bit
TextureCaching = 2 ; Caching type: 0-3, def=2, mode 3 is not available on most cards
EnableKeys = 1 ; Enable renderer keys: 0/1, def=1 (enables keys for the fps menu/pause)
FastExcel = 0 ; Speed hack for SF 'excel' modes. Will cause glitches if enabled!
Here is my controller.cfg file (it is mapped to the keys I use so it might not be of any use to you)
[general]
noerrror=1
output=C:\Zinc\ControllerError.log
[all]
test=k2b
services=k1b
[player1]
useMM=1
coin=k06
start=k02
up=kc8
down=kd0
right=kcd
left=kcb
btn1=k2c
btn2=k2d
btn3=k2e
btn4=k34
btn5=k39
btn6=k33
btn9=k35
btn10=k34
btn11=k39
btn12=k33
btn13=k2c
[player2]
useMM=1
coin=k07
start=k03
up=k13
down=k21
right=k22
left=k20
btn1=k17
btn2=k25
btn3=k24
btn4=k1f
btn5=k10
btn6=k11
btn9=k1e
btn10=k1f
btn11=k10
btn12=k11
btn13=k17
