Hello...
question... Mame Screensaver finish without press a key...
the Log-File shows:
Key/Joy press detected: Exiting Attract mode: 78:120
what is this for an Key/Joy?
thx
I would say you have a button stuck on your joypad/cabinet/computer and it's causing Attract Mode to exit.
If you hit any button during Attract Mode it'll 'wake up' GameEx.
Hope that helps! :)
Hope that helps! :)
no.. all buttons, keys are okay... i have keyboard and gamepad..
i have the answear: Tom Speirs says is "F9"
the Screensaver dont work with Mame32 Plus 106.3New Render.. i have change to the original mame.exe and it works fine..
