Hello , it's a long time since I last wrote here . a hug to everyone and especially to Tom Speirs ^_^ .
I updated mame and I have a serious problem in the inclusion of roms into GameEx . Look at the pictures below, after two errors instead of thousands of roms there are 116 only.
It 's a new clean installation of GameEx and of mame . 0.174 .
I did tests with old mame version but nothing to do, the same problem
help me :(... thanks
GameEx.ini
Its very weird to get those message boxes in MAME but basically by the look of it you need to "turn off" "touch screen" support in GameEx.
Hope this helps.
Cheers.
Tom.
EnableTouchScreen=False
the same problem
What do I do now ?
Obviously I update the list.
I have tried all versions of mame 0.174 and my old 0.144 but the same problem (with this gameex version)
It looks like touchscreen is causing it. That would produce a list of only gun and mouse games but its still very strange of MAME to produce message boxes like that. That is coming from MAME not GameEx. So that is definitely odd.
i have edit my gameex.ini  :
now :
Touchscreen_Enabled=0
I have the same problem !!!!!
With my old mame 0,144 i have not messages by mame but roms visible are very few anyway
Please make sure no GameEx tasks are running in the task manager including "GameEx background"
Then check the ini
Then update the list
Then do the first again
Then post log and ini here.
Cheers.
Tom
ok now the error messages persist but number of roms are 3694 (it's correct? mameufx64 are 9891 available) .
ah ok , with the new gameex there are more default flters. I was at some years ago :rolleyes:
thanks
