HI,
First, thanks for awesome product. I setup 3 emulators on it N64 NES and SNES. When i run GameEx the only Emulator that allows me to create snaps is N64 the other emulators do not have that option, instead they only have sort by this and that options. Inside Advanced Configuration i have enabled Snaps for all, and also specified directories. Any idea?
NVM, i found the problem in the FAQ. Thanks
I guess second question how do u make movies for NES/SNES besides the option to go out and buy the movies from someone who already made them.
If you have a client that handles torrents, you shouldn't have to BUY them, per se. I believe Tom has a link to EmuMovies under the Links section of his website. If you got HiSpeed Internet, grab a client (like BitComet or Bit Lord) and download the packs yourself.
Of course, you can always create your own too. :)
Bittorrent has been the best new program written since the creation of DOS in my opinion. Of course, I'm referring to it's lega uses ;) I prefer the Azureus client myself. I used to use BitTornado but Azureus is a much better client for seeding and for setting up ban filters from government spies (just in case).
