EmuMovies Nintendo Gameboy Advance AVI Game Previews Released!!
www.emumovies.com
06/11/06
798 Files 5.08GB
320x240 128MP3
This is the US Set of Game previews for the Nintendo Gameboy Advance. I captured all images using VisualBoy Advance,
so any games that didn't seem playable with this emulator were not captured.
The previews consist of a sampling of gameplay. Some are as short as 30 seconds and some are longer than 2 minutes.
It just depended on the game and what I felt needed to be captured in order to achieve a good sampling. Remember
MameWah and 3D Arcade frontends loop the avi files so I kept that in mind when ripping.
Use in frontends such as MameWah, 3D Arcade, GameEX, Mala, and Atomic FE
As always samples will be located at www.emumovies.com
You can download the free DIVX decoder at www.divx.com, make sure that you disable the divx logo in the decoder's
settings for best results.
EmuMovies Release List
03/19/05 - Nintendo Entertainment System AVI Game Intros
04/11/05 - Sega Game Gear AVI Game Previews
04/24/05 - Turbo Grafx 16 AVI Game Previews
05/16/05 - Nintendo 64 AVI Game Previews
05/18/05 - Vectrex AVI Game Previews
05/19/05 - Atari 5200 AVI Game Previews
05/19/05 - Atari 7800 AVI Game Previews
05/29/05 - Atari Lynx AVI Game Previews
05/29/05 - NeoGeo Pocket AVI Game Previews
06/04/05 - Sega 32X AVI Game Previews
06/04/05 - Nintendo Super Gameboy AVI Game Previews
06/09/05 - Video Game Commercial Pack for MameWah
06/09/05 - Daphne LaserDisc AVI Game Previews
06/09/05 - Adventurevision AVI Game Previews
06/26/05 - Super Nintendo AVI Game Previews
11/12/05 - Sega Genesis AVI Game Previes
11/20/05 - Sega Master System AVI Game Previews
11/27/05 - Capcom CPS-1/CPS-2 AVI Game Previews
11/27/05 - SNK Neo-Geo AVI Game Previews
12/08/05 - Video Game Commercial Commercial Pack v2.0
03/05/06 - Atari 2600 AVI Game Previews
03/22/06 - Nintendo Gameboy Color AVI Game Previews
06/11/06 - Nintendo Gameboy Advance AVI Game Previews
I'm having some issues with these movies. If I use the Divx codec I can play them in WMP with no problem. However, if I try to use these movies in my Snap\Video directory, GameEx pukes when it try's to play them.
I've seen other posts that say GameEx needs to use the FFDShow codec to work properly; however when I had the FFDShow codec installed, the movies worked in GameEx but there was a 10 second or so delay before they would show any video (sound was okay).
Any ideas?
I've never been able to download from that site. i always get 'you are not authorized to view this torrent
UPDATE
After uninstalling the Divx codec from add/remove programs and then installing FFDshow again I finally got these vids working in GameEx.
My problem seemed to be that I was using an older version of FFDshow. If you run into problems make sure you've got the latest daily build. Me = noob.
Anyway, these vids look great. Top notch work Circo.
