Hello, I just found this piece of software and am really excited to get it up and running. I've been looking around for some sort of manual, but haven't been able to find it. Can any one help me out with getting this running? I've got mame installed, game ex installed and I'm trying to run console emulators (namely znes and an nes emulator) right now. Thanks!
You Should start here http://tomspeirs.com/gameex/docs.htm (documentation page). You can also check out http://www.gameex.info/forums/index.php?showtopic=3 , this is the forum for User Submitted Configs and Databases which will help you figure out what changes to make for whichever emu you are working on. Also you can use the search feature in the forums to find an answer to a specific question you may have. I suggest using the search BEFORE you post questions as many of them will have been asked before. Last but not least try the GameEx chat room at http://tomspeirs.com/gameex/chat.php . Hope this helps, and to be honest, GameEx is one of the easiest front ends to work with so have fun.
Jay T
