I'm sure I have something setup incorrectly in PBX but not sure what. See attached. Mame is not appearing in the front end. I have it working fine outside PBX, it just won't show in the menu when executing PBX.
post-28986-0-44833300-1455547454_thumb.p
OK, just realized the games are there but they are mixed in with the pinball tables. I was expecting a separate list called mame to appear since game mgr has it setup separately. why would I not be seeing a separate list called mame in my menu? I have attached the requested files in case you still need them. Gonna read the section in the pbx manual on this as well to see if I missed anything
PinballX.ini
Find your PinballX/Databases/MAME/MAME.xml file.
Make a copy of the file. Call it Arcade.xml.
Go back to your MAME.xml and edit it.
Clear all games and leave only the following two lines as the content of MAME.xml:
<menu>
</menu>
Now when you start PinballX you will have a new menu item called "Arcade" (or probably "Arcade Tables")
When you click the Arcade menu item it will take you to a secondary wheel that has your MAME games.
