I finally got my cab totally built and all the parts installed :D !
After some troubleshooting I finally got my 29" wells gardenr to display properly with ultimarcs ArcadeVGA card.
I can run Mame32 gui and the such just fine.
When I start gameex however, i loose my vertical hold immediatly (starts during the gameex nag screen).
I have tried turning on "yes" under the arcadevga mode in the configuration, and that ddin't seem to change anything.
Any suggestions? I NEEEEED my amazing Gameex frontend to work, lol.
It sounds like you just need to run GameEx at a different resolution. Under Display settings try setting it to 640 X480 or 640X288
I told gameex to stop changing the resolution and that seemed to fix it. Now Im just going through and testing different emulators to make sur ethey support proper resolution.
Thanks for the quick response Tom.
-Anthony
