Hi Tom-
Just a question to see if you know if GAMEEX has any issues with Vista. I have a developer version I am testing within a few weeks, to test on a network level at work, and was curious to see if you have had a chance to try it with GAMEEX. If not, I will try it and let you know!
Hi Tom-
Hi Ricci, I don't know if it works, but I'd like to know.
Thanks.
Tom.
  • 1 month later...
Sorry if this has been answered. I certainly couldn't find the answer.
Can anyone confirm if the latest Game EX will install and run with Vista Media Center that has been released to the public?
If not, are there any timeframes on when support for Vista will be added?
Appericate it.
Hello-
Sorry, I have not had time to test the beta Vista yet-I will try and load it up and give a report as soon as I test it out!
Well I decided to give it a shot on a freshly installed Vista Beta 2.
Windows Vista has a compatibility issue with Microsoft.NET 1.1 and won't let the program install, thus GameEX will not install.
Any plans on updating GameEX to only support .NET 2.0?
Can you try applying this registry entry, GameEx should install then.
net1.1.zip
GameEX finishes downloading the default themes and I get the following error box.
UpgradeConfig.exe -.NET Framework Initialization Error
To run this application, you first must install one of the following versions of the .NET Framework:
v1.1.4322
v1.0.3705
Contact your application publisher for instructions about obtaining the appropriate version of the .NET Framework.
Then the installer finishes (after much hard drive access). When I try to run GameEX from Start, I get the above error message. When I run Media Center, I do NOT see My Games listed.
Hope that helps.
Well I decided to give it one last try.
I forced Vista to install .NET 1.1 Framework and even .NET 1.1 SP 1.
After rebooting the system, I have to tell Vista to accept the incompatible program (.NET 1.1).
I then installed GameEX and when I attempt to run it from Start, I get the following error from GameEX:
a05:30:18.7 20/06/2006: GameEx: Version 6.36: Starting Log
05:30:18.7 20/06/2006: Operating System Platform: Win32NT
05:30:18.7 20/06/2006: Operating System Name: Windows XP
05:30:18.7 20/06/2006: Operating System Version: 5.1.2600
05:30:18.7 20/06/2006: Checking for versions of .net Framework installed
05:30:18.7 20/06/2006: .net Framework 1.1 Installed
05:30:18.7 20/06/2006: .net Framework 2.0 Installed
05:30:18.7 20/06/2006: Checking Registration
05:30:18.7 20/06/2006: Running Randomize()
05:30:18.7 20/06/2006: Checking for applications to Launch On Startup
05:30:18.7 20/06/2006: Initialising Video/MNG DLL's
05:30:18.7 20/06/2006: Running Misc startup tasks
05:30:18.7 20/06/2006: Setting Menu types
05:30:18.7 20/06/2006: Opening Configuration File
05:30:18.7 20/06/2006: Getting Configuration Values
05:30:18.7 20/06/2006: Using Theme: Default - Default
05:30:18.7 20/06/2006: Checking for alternate Image Directory for Theme: Default - Default
05:30:18.7 20/06/2006: Launching HideOS.exe
05:30:19.6 20/06/2006: Hiding Taskbar
05:30:19.6 20/06/2006: Is Media Center running?
05:30:19.6 20/06/2006: Checking/Creating LCD Registry values
05:30:19.6 20/06/2006: Check Media Center Exit/Start Mode
05:30:19.6 20/06/2006: Media Center Mode 2
05:30:19.6 20/06/2006: Text/Language: English
05:30:19.6 20/06/2006: Applying Language/Text
05:30:19.7 20/06/2006: Snap Delay set to: 1
05:30:19.7 20/06/2006: Get other settings
05:30:19.7 20/06/2006: Set: Find emulator artwork on best match basis
05:30:19.7 20/06/2006: Start work for Form
05:30:19.7 20/06/2006: Getting Original Screen Size
05:30:19.7 20/06/2006: Loading ICON
05:30:19.7 20/06/2006: Initializing Component
05:30:19.8 20/06/2006: Initialising Bass Audio Library
05:30:19.9 20/06/2006: Loading default loading screen
05:30:20.0 20/06/2006: Using 2D Animations
05:30:20.0 20/06/2006: Using General Font: Trebuchet MS
05:30:20.0 20/06/2006: Using Title Font: Trebuchet MS
05:30:20.0 20/06/2006: Starting GameExtender Publisher
05:30:20.0 20/06/2006: Initialising DirectDraw
05:30:20.0 20/06/2006: Applying GameEx is Loading Image
05:30:20.0 20/06/2006: Creating DirectDraw Device
05:30:20.1 20/06/2006: Setting Resolution to 800x600 32 bit color
05:30:22.6 20/06/2006: Cannot Set Resolution
05:30:22.6 20/06/2006: Trying current windows resolution
05:30:22.6 20/06/2006: Creating DirectDraw Surfaces
05:30:22.6 20/06/2006: Creating Primary Surface - Full Screen Mode
05:30:22.6 20/06/2006: Creating Back Buffer
05:30:22.6 20/06/2006: Loading graphic surfaces
05:30:22.6 20/06/2006: Creating Surfaces Misc and Dialogs
05:30:22.6 20/06/2006: Creating Surface Volume
05:30:22.6 20/06/2006: Creating Surfaces Arrows
05:30:22.6 20/06/2006: Creating Surfaces GameEXlogo Text
05:30:22.6 20/06/2006: Creating Surfaces Toolbar
05:30:22.7 20/06/2006: Creating Surfaces Backgrounds
05:30:23.4 20/06/2006: Creating Surfaces Toolbar Controls
05:30:23.4 20/06/2006: Creating Surfaces GameEx Logo
05:30:23.4 20/06/2006: Creating Surfaces Home & Exit
05:30:23.4 20/06/2006: Creating Surfaces Snaps
05:30:23.4 20/06/2006: Creating Surfaces Menu and List Bars
05:30:23.5 20/06/2006: Creating Fonts
05:30:23.5 20/06/2006: Creating Menu Font
05:30:23.6 20/06/2006: Creating Game Font
05:30:23.6 20/06/2006: Creating Game Font Standard Size
05:30:24.3 20/06/2006: Creating Font Black
05:30:24.4 20/06/2006: Creating Font Black Small
05:30:24.5 20/06/2006: Creating Game Font Faded
05:30:24.5 20/06/2006: Creating Title Font
05:30:24.9 20/06/2006: Creating Control Panel Font
05:30:25.6 20/06/2006: Fonts Created Succesfully
05:30:25.6 20/06/2006: Initialising Windows Media Player Component
05:30:25.6 20/06/2006: MAME Path is: g:\mame32
05:30:25.7 20/06/2006: MAME EXE file is: mame32fxpp.exe
05:30:25.7 20/06/2006: ROM Path is: G:\-DATA-\-MAME ROMS-
05:30:25.7 20/06/2006: Catver.ini is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\catver.ini
05:30:25.7 20/06/2006: controls.ini is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\data\controls.ini
05:30:25.7 20/06/2006: History.dat is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\history.dat
05:30:25.7 20/06/2006: nplayers.ini is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\nplayers.ini
05:30:25.7 20/06/2006: MAMEinfo.dat is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\mameinfo.dat
05:30:25.7 20/06/2006: Loading Controls.ini map file
05:30:25.7 20/06/2006: Loading Custom Emulators
05:30:25.9 20/06/2006: Snap Path is: g:\Mame32\snap
05:30:25.9 20/06/2006: AVI Snap Path is: G:\Mame32\MAMEMNG\ingame
05:30:25.9 20/06/2006: Flyer Path is: g:\Mame32\flyers
05:30:25.9 20/06/2006: Cabinet Path is: g:\Mame32\cabinets
05:30:25.9 20/06/2006: Title Path is: G:\Mame32\titles
05:30:25.9 20/06/2006: Panel Path is: G:\Mame32\panels
05:30:25.9 20/06/2006: Icon Path: Not Found
05:30:25.9 20/06/2006: Marquee Path is: G:\Mame32\marquees
05:30:25.9 20/06/2006: MAME CMD options: -triplebuffer -nowindow -joy
05:30:25.9 20/06/2006: Attempting to load game list
05:30:26.1 20/06/2006: Loading last used Game List
05:30:26.1 20/06/2006: Setting Music Volume
05:30:26.1 20/06/2006: Creating DirectSound Device
05:30:26.1 20/06/2006: Trying: Primary Sound Driver
05:30:26.1 20/06/2006: Loading Sound Files
05:30:26.1 20/06/2006: DirectSound Device Created Successfully
05:30:26.1 20/06/2006: Initialising DirectInput for Gamepad support
05:30:26.1 20/06/2006: Unable to create a joystick device
05:30:26.1 20/06/2006: Playing Startup Video
05:30:27.2 20/06/2006: Playing intro sound file
05:30:27.2 20/06/2006: Initializing MCE Remote
05:30:27.2 20/06/2006: Initialization OK! Starting GameEx!
05:30:27.2 20/06/2006: Testing Main Loop Once: Processing Frame
05:30:27.4 20/06/2006: Testing Main Loop Once: Main Loop ran successfully
05:30:28.6 20/06/2006: Exiting GameEx!
05:30:28.6 20/06/2006: Saving Settings
05:30:30.6 20/06/2006: Checking for applications to Launch On Exit
16:48:52.3 6/30/2006: GameEx: Version 6.36: Starting Log
16:48:52.3 6/30/2006: Operating System Platform: Win32NT
16:48:52.3 6/30/2006: Operating System Name: Unknown
16:48:52.3 6/30/2006: Operating System Version: 6.0.5384
16:48:52.3 6/30/2006: ERROR: An error occured while checking for previous instance of GameEx
16:48:52.3 6/30/2006: This can be caused by a bad windows or .net framework install.
16:48:52.3 6/30/2006: GameEx will likely function incorrectly as it cannot check for running processes
16:48:52.3 6/30/2006: GameEx will now exit with errors
16:48:52.3 6/30/2006: Error: 1 - Application-defined or object-defined error.
So its back to uninstalling everything.
Tom, just as a friendly nudge if you will....here's a great link that I found:
http://www.microsoft.com/downloads/details...&displaylang=en
Vista Media Center is a great improvement over MCE 2005 and at this point its been running very smoothly and without any problems. I do not see myself going through the trouble of reverting back to MCE 2005 and it's unfortunate that I will have to make due without GameEX.
Thanks for your time.
I actually installed the Beta 2 this morning, and did the same thing and got the thing.
I dont plan to make GameEx only run on Vista WMC, which is actually what that download proposes, but I do plan to make it run on Vista. I don't need a nudge, just more money, or more time, but thanks a lot for testing it out for me, and for the link.
I expect GameEx to run on Vista perfectly come the release to manufacuting, which seems like could be 6-8 months off.
Thanks again.
Tom
Tom,
I can most certainly apperciate that time, effort and cost you have put into GameEX. The product is without doubt, great.
My goal with my new system was to run Media Center, and all other things are secondary. To me, the latest version of WMC is better than the older version. I have spent a lot of time myself builting this system, and tweaking the old OS and now the new OS. As much as I want and enjoy GameEX, I will have to patiently wait.
I hope you do consider adding a Start Page for the new WMC.
Thanks again and I'll keep my eyes out when you need any Vista Testers.
p.s. Even though I cannot use GameEX, I'll make a donation for the cause. Thank you.
