Hello
is it normal that the update is so long??
About 45 minutes with a complete set 0.103 :huh:
With mame32, it take about 5 minutes
thanks
Hello
thanks
Its normal. GameEx does a lot more than what MAME32 does when updating.
ok I suspected it :)
But it is possible to deactivate some updates ?
Or to choose what is necessary to update or not ??
thank you
thank you
Yes, yourll get a big improvement by changing these two settings.
Turn off Verify Roms.
Make sure MAMEInfo.dat setting is blank.
Your' lose recommended games, and unless you've verified your roms in a rom tool, a few games may be listed that won't run.
