I have been using gameex for a little while now and I have run into a few issues that I was wondering if anyone else had. I am using the latest version.
-I noticed that when I use a custom background for an emulator that after playing a game when it returns to gameex it no longer shows the custom background for that emulator.
-A couple of times part of my mame gamelist has disappeared. Like from the letter S on.
-I noticed that after adding a game to my favorites list and shutting down my computer without exiting gameex that the game will not be in the favorites list when I return to gameex. P.S. I have exit disabled on gameex and I use the button on my computer to perform the shutdown. If this isn't a good idea with gameex plz let me know.
-Also I have the same problem other people have described when launching games from the favorites list that it launches a totally different game.
-I updated the text under the text/language option in the configuration menu and it has no affect on the text in gameex. I instead have to manually edit the config file.
-After updating to the latest version of gameex the majority of the themes cause gameex to crash. For most themes the crash occurs when trying to launch a mame or daphne game, or when trying to update the mame list. And a few of the themes will not let gameex load up at all.
-The theme editor doesn't seem to want to save changes half of the time.
There are a few other minor things but these are the main ones.
Thanks for the feedback. I think a lot of these issues have been fixed in recent versions. Can you confirm which ones are still happening in the latest version, and give me some more detail?
Many thanks.
Tom
Many thanks.
Tom
Hi, Could you please post the logs, for when the themes crash? Thanks again for your feedback, I'm fixing the custom background issue now.
Thanks for the quick response. Here is the log when I try to load a game when using the soul calibur theme.
16:33:51.8 5/20/2006: GameEx: Version 6.08: Starting Log
16:33:51.8 5/20/2006: Operating System Platform: Win32NT
16:33:51.8 5/20/2006: Operating System Name: Windows XP
16:33:51.8 5/20/2006: Operating System Version: 5.1.2600
16:33:51.8 5/20/2006: Checking for versions of .net Framework installed
16:33:51.8 5/20/2006: .net Framework 1.1 Installed
16:33:51.8 5/20/2006: Checking Registration
16:33:51.8 5/20/2006: Running Randomize()
16:33:51.8 5/20/2006: Checking for applications to Launch On Startup
16:33:51.8 5/20/2006: Initialising Video/MNG DLL's
16:33:51.9 5/20/2006: Running Misc startup tasks
16:33:51.9 5/20/2006: Setting Menu types
16:33:51.9 5/20/2006: Opening Configuration File
16:33:51.9 5/20/2006: Getting Configuration Values
16:33:51.9 5/20/2006: Using Theme: Default - Soul Calibur
16:33:51.9 5/20/2006: Checking for alternate Image Directory for Theme: Default - Soul Calibur
16:33:51.9 5/20/2006: Launching HideOS.exe
16:33:53.3 5/20/2006: Hiding Taskbar
16:33:53.4 5/20/2006: Is Media Center running?
16:33:53.4 5/20/2006: Check Media Center Exit/Start Mode
16:33:53.4 5/20/2006: Media Center Mode 2
16:33:53.4 5/20/2006: Text/Language: English
16:33:53.4 5/20/2006: Applying Language/Text
16:33:53.4 5/20/2006: Creating Scancodes.txt (List of DirectInput scan codes)
16:33:53.5 5/20/2006: Snap Delay set to: 1
16:33:53.5 5/20/2006: Get other settings
16:33:53.5 5/20/2006: Set: Find emulator artwork on best match basis
16:33:53.5 5/20/2006: Start work for Form
16:33:53.5 5/20/2006: Getting Original Screen Size
16:33:53.5 5/20/2006: Loading ICON
16:33:53.6 5/20/2006: Initializing Component
16:33:53.7 5/20/2006: Initialising Bass Audio Library
16:33:54.3 5/20/2006: Loading default loading screen
16:33:54.3 5/20/2006: Using 3D Alpha Blended Animations. This could be slow
16:33:54.3 5/20/2006: Using General Font: HandelGothic BT
16:33:54.3 5/20/2006: Using Title Font: HandelGothic BT
16:33:54.3 5/20/2006: Initialising DirectDraw
16:33:54.5 5/20/2006: Creating DirectDraw Device
16:33:54.5 5/20/2006: Using Device: RADEON 9600 PRO Family (Microsoft Corporation)
16:33:54.6 5/20/2006: Setting Resolution to 640x480 32 bit color
16:33:55.1 5/20/2006: Creating DirectDraw Surfaces
16:33:55.1 5/20/2006: Creating Primary Surface - Full Screen Mode
16:33:55.2 5/20/2006: Creating Back Buffer
16:33:55.3 5/20/2006: Loading graphic surfaces
16:33:55.5 5/20/2006: Creating Surfaces Misc and Dialogs
16:33:55.9 5/20/2006: Creating Surface Volume
16:33:55.9 5/20/2006: Creating Surfaces Arrows
16:33:56.0 5/20/2006: Creating Surfaces GameEXlogo Text
16:33:56.0 5/20/2006: Creating Surfaces Toolbar
16:33:56.2 5/20/2006: Creating Surfaces Backgrounds
16:34:00.8 5/20/2006: Creating Surfaces Toolbar Controls
16:34:00.9 5/20/2006: Creating Surfaces GameEx Logo
16:34:00.9 5/20/2006: Creating Surfaces Home & Exit
16:34:01.1 5/20/2006: Creating Surfaces Snaps
16:34:01.2 5/20/2006: Creating Surfaces Menu and List Bars
16:34:02.2 5/20/2006: Creating Fonts
16:34:02.2 5/20/2006: Creating Menu Font
16:34:03.9 5/20/2006: Creating Game Font
16:34:04.8 5/20/2006: Creating Game Font Standard Size
16:34:05.2 5/20/2006: Creating Font Black
16:34:05.3 5/20/2006: Creating Font Black Small
16:34:05.4 5/20/2006: Creating Game Font Faded
16:34:06.3 5/20/2006: Creating Title Font
16:34:11.0 5/20/2006: Creating Control Panel Font
16:34:11.4 5/20/2006: Fonts Created Succesfully
16:34:11.4 5/20/2006: Initialising Windows Media Player Component
16:34:11.6 5/20/2006: MAME Path is: C:\MinGW\mame
16:34:11.6 5/20/2006: daphne Path is: C:\Emulators\Daphne
16:34:11.6 5/20/2006: daphne EXE file is: Daphne.exe
16:34:11.6 5/20/2006: Use daphne on. Daphne.exe will launch games
16:34:11.7 5/20/2006: Model 2 Path Path is: C:\Emulators\Nebula
16:34:11.7 5/20/2006: Model 2 EXE file is: emulator.exe
16:34:11.7 5/20/2006: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
16:34:11.7 5/20/2006: ZiNc Path is: C:\Emulators\Zinc
16:34:11.7 5/20/2006: ZiNc EXE file is: zinc.exe
16:34:11.8 5/20/2006: Use ZiNc on. zinc.exe will launch PSX games
16:34:11.8 5/20/2006: MAME EXE file is: mame.exe
16:34:11.9 5/20/2006: ROM Path is: E:\roms\arcade\92roms
16:34:12.0 5/20/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
16:34:12.0 5/20/2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
16:34:12.0 5/20/2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
16:34:12.0 5/20/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
16:34:12.0 5/20/2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
16:34:12.1 5/20/2006: Loading Controls.ini map file
16:34:12.1 5/20/2006: Loading Custom Emulators
16:34:12.1 5/20/2006: Loading Emulator 1: Nintendo 64 Games
16:34:12.2 5/20/2006: Loading OfflineList Dat File for emulator: 1
16:34:12.2 5/20/2006: Cannot Find Offline List Dat File
16:34:12.2 5/20/2006: Loading Emulator 2: Super Nintendo games
16:34:12.3 5/20/2006: Loading OfflineList Dat File for emulator: 2
16:34:12.3 5/20/2006: Cannot Find Offline List Dat File
16:34:12.3 5/20/2006: Loading Emulator 3: Pinball Games
16:34:12.4 5/20/2006: Loading Emulator 4: Nintendo NES Games
16:34:12.5 5/20/2006: Loading Emulator 5: Atari 2600 Games
16:34:12.6 5/20/2006: Loading Emulator 6: PC Apps
16:34:12.6 5/20/2006: Loading Emulator 7: Sega Genesis Games
16:34:13.0 5/20/2006: Snap Path is: c:\emulators\mame\snap
16:34:13.0 5/20/2006: AVI Snap Path is: E:\videos\arcade
16:34:13.0 5/20/2006: Flyer Path is: c:\emulators\mame\flyers
16:34:13.0 5/20/2006: Cabinet Path is: c:\emulators\mame\cabinets
16:34:13.0 5/20/2006: Title Path is: c:\emulators\mame\titles
16:34:13.0 5/20/2006: Panel Path: Not Found
16:34:13.0 5/20/2006: Icon Path: Not Found
16:34:13.0 5/20/2006: Marquee Path: Not Found
16:34:13.0 5/20/2006: MAME CMD options:
16:34:13.0 5/20/2006: Attempting to load game list
16:34:13.8 5/20/2006: Running: mame.exe -help
16:34:13.9 5/20/2006: Running: C: C:\MinGW\mame\mame.exe -help > C:\MinGW\mame\help.txt
16:34:17.1 5/20/2006:
16:34:17.1 5/20/2006: Now Outputing mame.exe - Help
16:34:17.1 5/20/2006: --BEGIN--
16:34:17.1 5/20/2006: M.A.M.E. v0.98 (Jul 25 2005) - Multiple Arcade Machine Emulator
16:34:17.1 5/20/2006: Copyright © 1997-2005 by Nicola Salmoria and the MAME Team
16:34:17.1 5/20/2006: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
16:34:17.1 5/20/2006: several arcade machines. But hardware is useless without software, so an image
16:34:17.1 5/20/2006: of the ROMs which run on that hardware is required. Such ROMs, like any other
16:34:17.1 5/20/2006: commercial software, are copyrighted material and it is therefore illegal to
16:34:17.1 5/20/2006: use them if you don't own the original arcade machine. Needless to say, ROMs
16:34:17.1 5/20/2006: are not distributed together with MAME. Distribution of MAME together with ROM
16:34:17.1 5/20/2006: images is a violation of copyright law and should be promptly reported to the
16:34:17.1 5/20/2006: authors so that appropriate legal action can be taken.
16:34:17.1 5/20/2006: Usage: MAME gamename [options]
16:34:17.1 5/20/2006: MAME -list for a brief list of supported games
16:34:17.1 5/20/2006: MAME -listfull for a full list of supported games
16:34:17.1 5/20/2006: MAME -showusage for a brief list of options
16:34:17.1 5/20/2006: MAME -showconfig for a list of configuration options
16:34:17.1 5/20/2006: MAME -createconfig to create a mame.ini
16:34:17.1 5/20/2006: For usage instructions, please consult the file windows.txt
16:34:17.1 5/20/2006: --END--
16:34:17.1 5/20/2006: Loading last used Game List
16:34:17.1 5/20/2006: Setting Music Volume
16:34:17.1 5/20/2006: Creating DirectSound Device
16:34:17.1 5/20/2006: Trying: Primary Sound Driver
16:34:17.2 5/20/2006: Loading Sound Files
16:34:17.4 5/20/2006: DirectSound Device Created Successfully
16:34:17.4 5/20/2006: Initialising DirectInput for Gamepad support
16:34:17.5 5/20/2006: Unable to create a joystick device
16:34:17.5 5/20/2006: Playing intro sound file
16:34:17.5 5/20/2006: Initializing MCE Remote
16:34:17.5 5/20/2006: Initialization OK! Starting GameEx!
16:34:17.6 5/20/2006: Testing Main Loop Once: Processing Frame
16:34:18.0 5/20/2006: Testing Main Loop Once: Main Loop ran successfully
16:34:50.3 5/20/2006: 21 Consecutive Exceptions Occured: Exiting
16:34:50.3 5/20/2006: Object reference not set to an instance of an object.
16:34:50.5 5/20/2006: at GameEx.GameEx.mainform.PlayLaunchWAV()
16:34:50.5 5/20/2006: at GameEx.GameEx.mainform.LaunchSelectedMAMEGame()
16:34:50.5 5/20/2006: at GameEx.GameEx.mainform.processgamemenu()
16:34:50.5 5/20/2006: at GameEx.GameEx.mainform.DisplayFrame()
16:34:53.5 5/20/2006: Exiting GameEx!
16:34:53.5 5/20/2006: Saving Settings
16:34:55.4 5/20/2006: Checking for applications to Launch On Exit
OK, thanks, will be fixed in next release. I can see the problem, and someone else had it too.
  • 4 weeks later...
the 6.32 release of gameex i have installed on win 98 have a problem with Daphne. Daphne's games run correctly under gameex but when i exit any emulated lasergame, gameex crash (i see the win desktop and when i press ctrl+alt+canc i can see gameex run in background) For any other thing, gameex run correctly.
What can i do? :mellow:
