I updated to version 6.08 and gameex now keeps crashing when I would try to load a game. I did a fresh install of gameex on another computer to see if that would fix it and it still keeps crashing. I downloaded version 6.10 to see if that would fix my issues and I am still having pretty much the same issue. I tried using different themes including the default theme that is packaged with version 6.10 and that did not help. Some themes will even prevent gameex from loading up at all. Below is my log file.
09:42:25.6 5/18/2006: GameEx: Version 6.08: Starting Log
09:42:25.7 5/18/2006: Operating System Platform: Win32NT
09:42:25.7 5/18/2006: Operating System Name: Windows XP
09:42:25.7 5/18/2006: Operating System Version: 5.1.2600
09:42:25.7 5/18/2006: Checking for versions of .net Framework installed
09:42:25.7 5/18/2006: .net Framework 1.1 Installed
09:42:25.7 5/18/2006: Checking Registration
09:42:25.7 5/18/2006: Running Randomize()
09:42:25.7 5/18/2006: Checking for applications to Launch On Startup
09:42:25.7 5/18/2006: Initialising Video/MNG DLL's
09:42:25.7 5/18/2006: Running Misc startup tasks
09:42:25.7 5/18/2006: Setting Menu types
09:42:25.7 5/18/2006: Opening Configuration File
09:42:25.7 5/18/2006: Getting Configuration Values
09:42:25.7 5/18/2006: Using Theme: Default - Tron
09:42:25.7 5/18/2006: Checking for alternate Image Directory for Theme: Default - Tron
09:42:25.7 5/18/2006: Launching HideOS.exe
09:42:27.0 5/18/2006: Hiding Taskbar
09:42:27.0 5/18/2006: Is Media Center running?
09:42:27.1 5/18/2006: Check Media Center Exit/Start Mode
09:42:27.1 5/18/2006: Media Center Mode 2
09:42:27.1 5/18/2006: Text/Language: English
09:42:27.1 5/18/2006: Applying Language/Text
09:42:27.1 5/18/2006: Creating Scancodes.txt (List of DirectInput scan codes)
09:42:27.1 5/18/2006: Snap Delay set to: 1
09:42:27.2 5/18/2006: Get other settings
09:42:27.2 5/18/2006: Set: Find emulator artwork on best match basis
09:42:27.2 5/18/2006: Start work for Form
09:42:27.2 5/18/2006: Getting Original Screen Size
09:42:27.2 5/18/2006: Loading ICON
09:42:27.3 5/18/2006: Initializing Component
09:42:27.4 5/18/2006: Initialising Bass Audio Library
09:42:27.7 5/18/2006: Loading default loading screen
09:42:27.8 5/18/2006: Using 3D Alpha Blended Animations. This could be slow
09:42:27.8 5/18/2006: Using General Font: Trebuchet MS
09:42:27.8 5/18/2006: Using Title Font: Trebuchet MS
09:42:27.8 5/18/2006: Initialising DirectDraw
09:42:27.8 5/18/2006: Error: GameEx cannot rotate the display at a resolution greater than 1024 X 576
09:42:27.8 5/18/2006: Turning off rotation
09:42:27.8 5/18/2006: Applying GameEx is Loading Image
09:42:27.9 5/18/2006: Creating DirectDraw Device
09:42:27.9 5/18/2006: Using Device: RADEON 8500 / RADEON 8500 LE (Microsoft Corporation)
09:42:28.0 5/18/2006: Setting Resolution to 1024x768 32 bit color
09:42:28.1 5/18/2006: Creating DirectDraw Surfaces
09:42:28.1 5/18/2006: Creating Primary Surface - Full Screen Mode
09:42:28.2 5/18/2006: Creating Back Buffer
09:42:28.2 5/18/2006: Loading graphic surfaces
09:42:28.3 5/18/2006: Creating Surfaces Misc and Dialogs
09:42:28.4 5/18/2006: Creating Surface Volume
09:42:28.5 5/18/2006: Creating Surfaces Arrows
09:42:28.5 5/18/2006: Creating Surfaces GameEXlogo Text
09:42:28.5 5/18/2006: Creating Surfaces Toolbar
09:42:28.6 5/18/2006: Creating Surfaces Backgrounds
09:42:31.0 5/18/2006: Creating Surfaces Toolbar Controls
09:42:31.1 5/18/2006: Creating Surfaces GameEx Logo
09:42:31.1 5/18/2006: Creating Surfaces Home & Exit
09:42:31.2 5/18/2006: Creating Surfaces Snaps
09:42:31.2 5/18/2006: Creating Surfaces Menu and List Bars
09:42:31.5 5/18/2006: Creating Fonts
09:42:31.5 5/18/2006: Creating Menu Font
09:42:32.6 5/18/2006: Creating Game Font
09:42:33.6 5/18/2006: Creating Game Font Standard Size
09:42:34.1 5/18/2006: Creating Font Black
09:42:34.2 5/18/2006: Creating Font Black Small
09:42:34.3 5/18/2006: Creating Game Font Faded
09:42:35.3 5/18/2006: Creating Title Font
09:42:39.5 5/18/2006: Creating Control Panel Font
09:42:39.9 5/18/2006: Fonts Created Succesfully
09:42:39.9 5/18/2006: Initialising Windows Media Player Component
09:42:39.9 5/18/2006: MAME Path is: c:\emulators\mame
09:42:40.0 5/18/2006: daphne Path is: C:\Emulators\Daphne
09:42:40.0 5/18/2006: daphne EXE file is: Daphne.exe
09:42:40.0 5/18/2006: Use daphne on. Daphne.exe will launch games
09:42:40.0 5/18/2006: ZiNc Path is: C:\Emulators\Zinc
09:42:40.0 5/18/2006: ZiNc EXE file is: zinc.exe
09:42:40.0 5/18/2006: Use ZiNc on. zinc.exe will launch PSX games
09:42:40.0 5/18/2006: MAME EXE file is: mame.exe
09:42:40.0 5/18/2006: ROM Path is: E:\roms\arcade\92roms
09:42:40.0 5/18/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
09:42:40.0 5/18/2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
09:42:40.0 5/18/2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
09:42:40.0 5/18/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
09:42:40.0 5/18/2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
09:42:40.1 5/18/2006: Loading Controls.ini map file
09:42:40.1 5/18/2006: Loading Custom Emulators
09:42:40.1 5/18/2006: Loading Emulator 1: Nintendo 64 Games
09:42:40.1 5/18/2006: Loading OfflineList Dat File for emulator: 1
09:42:40.1 5/18/2006: Cannot Find Offline List Dat File
09:42:40.1 5/18/2006: Loading Emulator 2: Super Nintendo games
09:42:40.2 5/18/2006: Loading OfflineList Dat File for emulator: 2
09:42:40.2 5/18/2006: Cannot Find Offline List Dat File
09:42:40.2 5/18/2006: Loading Emulator 3: Pinball Games
09:42:40.2 5/18/2006: Loading Emulator 4: Nintendo NES Games
09:42:40.3 5/18/2006: Loading Emulator 5: Atari 2600 Games
09:42:40.3 5/18/2006: Loading Emulator 6: PC Apps
09:42:40.4 5/18/2006: Loading Emulator 7: Sega Genesis Games
09:42:40.8 5/18/2006: Snap Path is: c:\emulators\mame\snap
09:42:40.8 5/18/2006: AVI Snap Path is: E:\videos\arcade
09:42:40.8 5/18/2006: Flyer Path is: c:\emulators\mame\flyers
09:42:40.8 5/18/2006: Cabinet Path is: c:\emulators\mame\cabinets
09:42:40.8 5/18/2006: Title Path is: c:\emulators\mame\titles
09:42:40.8 5/18/2006: Panel Path: Not Found
09:42:40.8 5/18/2006: Icon Path: Not Found
09:42:40.8 5/18/2006: Marquee Path: Not Found
09:42:40.8 5/18/2006: MAME CMD options: -triplebuffer -nowindow -joy
09:42:40.8 5/18/2006: Attempting to load game list
09:42:41.0 5/18/2006: Running: mame.exe -help
09:42:41.0 5/18/2006: Running: c: c:\emulators\mame\mame.exe -help > c:\emulators\mame\help.txt
09:42:41.6 5/18/2006:
09:42:41.6 5/18/2006: Now Outputing mame.exe - Help
09:42:41.6 5/18/2006: --BEGIN--
09:42:41.6 5/18/2006: M.A.M.E. v0.87 (Sep 21 2004) - Multiple Arcade Machine Emulator
09:42:41.6 5/18/2006: Copyright © 1997-2004 by Nicola Salmoria and the MAME Team
09:42:41.6 5/18/2006: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
09:42:41.6 5/18/2006: several arcade machines. But hardware is useless without software, so an image
09:42:41.6 5/18/2006: of the ROMs which run on that hardware is required. Such ROMs, like any other
09:42:41.6 5/18/2006: commercial software, are copyrighted material and it is therefore illegal to
09:42:41.6 5/18/2006: use them if you don't own the original arcade machine. Needless to say, ROMs
09:42:41.6 5/18/2006: are not distributed together with MAME. Distribution of MAME together with ROM
09:42:41.6 5/18/2006: images is a violation of copyright law and should be promptly reported to the
09:42:41.6 5/18/2006: authors so that appropriate legal action can be taken.
09:42:41.6 5/18/2006: Usage: MAME gamename [options]
09:42:41.6 5/18/2006: MAME -list for a brief list of supported games
09:42:41.6 5/18/2006: MAME -listfull for a full list of supported games
09:42:41.6 5/18/2006: MAME -showusage for a brief list of options
09:42:41.6 5/18/2006: MAME -showconfig for a list of configuration options
09:42:41.6 5/18/2006: MAME -createconfig to create a mame.ini
09:42:41.6 5/18/2006: For usage instructions, please consult the file windows.txt
09:42:41.6 5/18/2006: --END--
09:42:41.6 5/18/2006: Loading last used Game List
09:42:41.6 5/18/2006: Setting Music Volume
09:42:41.6 5/18/2006: Creating DirectSound Device
09:42:41.7 5/18/2006: Trying: Primary Sound Driver
09:42:41.7 5/18/2006: Loading Sound Files
09:42:42.0 5/18/2006: DirectSound Device Created Successfully
09:42:42.0 5/18/2006: Initialising DirectInput for Gamepad support
09:42:42.0 5/18/2006: Unable to create a joystick device
09:42:42.0 5/18/2006: Playing intro sound file
09:42:42.1 5/18/2006: Initializing MCE Remote
09:42:42.1 5/18/2006: Initialization OK! Starting GameEx!
09:42:42.1 5/18/2006: Testing Main Loop Once: Processing Frame
09:42:42.5 5/18/2006: Testing Main Loop Once: Main Loop ran successfully
09:42:56.5 5/18/2006: Validating: Emulator_1: Custom Background: E:\Videos\N64
09:42:56.5 5/18/2006: Warning: Emulator_1: Custom Background Does not exist
09:42:56.5 5/18/2006: Validating: Emulator_1: Snap Path: E:\Videos\N64
09:42:56.5 5/18/2006: Validating: Emulator_1: Database: N64
09:42:56.5 5/18/2006: Validating: Emulator_1: Title Snap Path:
09:42:56.5 5/18/2006: Warning: Emulator_1: Title Snap Path Does not exist
09:42:56.5 5/18/2006: Validating: Emulator_1: Box Art Path: C:\Emulators\Project64\Box
09:42:56.5 5/18/2006: Warning: Emulator_1: Box Art Path Does not exist
09:42:56.5 5/18/2006: Validating: Emulator_1: Cart Art Path: G:\zsnes\CartScans SNES USA
09:42:56.5 5/18/2006: Warning: Emulator_1: Cart Art Path Does not exist
09:42:56.5 5/18/2006: Warning: Emulator_1: MAPFile Does Not Exist
09:42:56.5 5/18/2006: Validating: Emulator_2: Custom Background: E:\Videos\Super Nintendo
09:42:56.5 5/18/2006: Warning: Emulator_2: Custom Background Does not exist
09:42:56.5 5/18/2006: Validating: Emulator_2: Snap Path: E:\Videos\Super Nintendo
09:42:56.5 5/18/2006: Validating: Emulator_2: Database:
09:42:56.5 5/18/2006: Warning: Emulator_2: Database Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_2: Title Snap Path: C:\Emulators\zsnes\titles
09:42:56.6 5/18/2006: Warning: Emulator_2: Title Snap Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_2: Box Art Path: C:\Emulators\zsnes\Boxscans_SNES_(USA)_28May04
09:42:56.6 5/18/2006: Warning: Emulator_2: Box Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_2: Cart Art Path: C:\Emulators\zsnes\CartScans SNES USA
09:42:56.6 5/18/2006: Warning: Emulator_2: Cart Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_3: Custom Background:
09:42:56.6 5/18/2006: Validating: Emulator_3: Snap Path:
09:42:56.6 5/18/2006: Warning: Emulator_3: Snap Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_3: Database:
09:42:56.6 5/18/2006: Warning: Emulator_3: Database Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_3: Title Snap Path:
09:42:56.6 5/18/2006: Warning: Emulator_3: Title Snap Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_3: Box Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_3: Box Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_3: Cart Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_3: Cart Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_4: Custom Background: E:\Videos\NES Title Sequences
09:42:56.6 5/18/2006: Warning: Emulator_4: Custom Background Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_4: Snap Path: E:\Videos\NES Title Sequences
09:42:56.6 5/18/2006: Validating: Emulator_4: Database:
09:42:56.6 5/18/2006: Warning: Emulator_4: Database Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_4: Title Snap Path: C:\Emulators\FCE Ultra\snaps\USA\titles
09:42:56.6 5/18/2006: Validating: Emulator_4: Box Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_4: Box Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_4: Cart Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_4: Cart Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_5: Custom Background: C:\Emulators\Z26\snap, E:\Videos\Atari 2600
09:42:56.6 5/18/2006: Warning: Emulator_5: Custom Background Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_5: Snap Path: C:\Emulators\Z26\snap, E:\Videos\Atari 2600
09:42:56.6 5/18/2006: Warning: Emulator_5: Snap Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_5: Database:
09:42:56.6 5/18/2006: Warning: Emulator_5: Database Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_5: Title Snap Path:
09:42:56.6 5/18/2006: Warning: Emulator_5: Title Snap Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_5: Box Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_5: Box Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_5: Cart Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_5: Cart Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_6: Custom Background: C:\PCGames\Snap
09:42:56.6 5/18/2006: Warning: Emulator_6: Custom Background Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_6: Snap Path: C:\PCGames\Snap
09:42:56.6 5/18/2006: Validating: Emulator_6: Database:
09:42:56.6 5/18/2006: Warning: Emulator_6: Database Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_6: Title Snap Path:
09:42:56.6 5/18/2006: Warning: Emulator_6: Title Snap Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_6: Box Art Path: C:\PCGames\cover
09:42:56.6 5/18/2006: Validating: Emulator_6: Cart Art Path: C:\PCGames\cd
09:42:56.6 5/18/2006: Validating: Emulator_7: Custom Background:
09:42:56.6 5/18/2006: Warning: Emulator_7: Custom Background Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_7: Snap Path:
09:42:56.6 5/18/2006: Warning: Emulator_7: Snap Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_7: Database:
09:42:56.6 5/18/2006: Warning: Emulator_7: Database Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_7: Title Snap Path: C:\Emulators\Gensfe\snap
09:42:56.6 5/18/2006: Validating: Emulator_7: Box Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_7: Box Art Path Does not exist
09:42:56.6 5/18/2006: Validating: Emulator_7: Cart Art Path:
09:42:56.6 5/18/2006: Warning: Emulator_7: Cart Art Path Does not exist
09:42:59.7 5/18/2006: 21 Consecutive Exceptions Occured: Exiting
09:42:59.7 5/18/2006: Object reference not set to an instance of an object.
09:42:59.7 5/18/2006: at GameEx.GameEx.mainform.PlayLaunchWAV()
09:42:59.7 5/18/2006: at GameEx.GameEx.mainform.LaunchEmu()
09:42:59.7 5/18/2006: at GameEx.GameEx.mainform.processgamemenu()
09:42:59.7 5/18/2006: at GameEx.GameEx.mainform.DisplayFrame()
09:43:05.4 5/18/2006: Exiting GameEx!
09:43:05.4 5/18/2006: Saving Settings
09:43:08.8 5/18/2006: Checking for applications to Launch On Exit
From a quick cursory search at your log, it appears you are not pointing to the right files with gameex. e.g, if you have an icon path such as c:mame/icons, you need to browse and point gameex there within the configuration tool. Make sense??
