:D hi all, i am a new member of this forum and a new user of GameEx!
I have a problem:
GameEx start but when i choose a game in the mame menu, the software crash!(the game run well with "Mame32Fx")
This is the log file:
00:48:32.8 15/05/2006: GameEx: Version 6.08: Starting Log
00:48:32.8 15/05/2006: Operating System Platform: Win32NT
00:48:32.8 15/05/2006: Operating System Name: Windows XP
00:48:32.8 15/05/2006: Operating System Version: 5.1.2600
00:48:32.8 15/05/2006: Checking for versions of .net Framework installed
00:48:32.8 15/05/2006: .net Framework 1.1 Installed
00:48:32.8 15/05/2006: Checking Registration
00:48:32.8 15/05/2006: Running Randomize()
00:48:32.8 15/05/2006: Checking for applications to Launch On Startup
00:48:32.8 15/05/2006: Initialising Video/MNG DLL's
00:48:32.8 15/05/2006: Running Misc startup tasks
00:48:32.8 15/05/2006: Setting Menu types
00:48:32.8 15/05/2006: Opening Configuration File
00:48:32.8 15/05/2006: Getting Configuration Values
00:48:32.8 15/05/2006: Using Theme: Default - Women We Love To Play
00:48:32.8 15/05/2006: Checking for alternate Image Directory for Theme: Default - Women We Love To Play
00:48:32.8 15/05/2006: GameEx will display on Secondary Device
00:48:32.8 15/05/2006: Launching HideOS.exe on secondary display
00:48:33.7 15/05/2006: Is Media Center running?
00:48:33.7 15/05/2006: Check Media Center Exit/Start Mode
00:48:33.7 15/05/2006: Media Center Mode 2
00:48:33.7 15/05/2006: Text/Language: French
00:48:33.7 15/05/2006: Applying Language/Text
00:48:33.8 15/05/2006: Creating Scancodes.txt (List of DirectInput scan codes)
00:48:33.8 15/05/2006: Snap Delay set to: 1
00:48:33.8 15/05/2006: Get other settings
00:48:33.8 15/05/2006: Set: Find emulator artwork on best match basis
00:48:33.8 15/05/2006: Start work for Form
00:48:33.8 15/05/2006: Getting Original Screen Size
00:48:33.8 15/05/2006: Loading ICON
00:48:33.9 15/05/2006: Initializing Component
00:48:33.9 15/05/2006: Initialising Bass Audio Library
00:48:34.0 15/05/2006: Loading default loading screen
00:48:34.0 15/05/2006: Using 2D Animations
00:48:34.0 15/05/2006: Using General Font: University Roman LET
00:48:34.0 15/05/2006: Using Title Font: University Roman LET
00:48:34.1 15/05/2006: Initialising DirectDraw
00:48:34.1 15/05/2006: Applying GameEx is Loading Image
00:48:34.1 15/05/2006: Creating DirectDraw Device: Secondary Device
00:48:34.1 15/05/2006: Using Device: GIGABYTE RADEON 9250
00:48:34.2 15/05/2006: Setting Resolution to 800x600 32 bit color
00:48:34.6 15/05/2006: Creating DirectDraw Surfaces
00:48:34.6 15/05/2006: Creating Primary Surface - Full Screen Mode
00:48:34.6 15/05/2006: Creating Back Buffer
00:48:34.7 15/05/2006: Loading graphic surfaces
00:48:34.7 15/05/2006: Creating Surfaces Misc and Dialogs
00:48:34.8 15/05/2006: Creating Surface Volume
00:48:34.8 15/05/2006: Creating Surfaces Arrows
00:48:34.8 15/05/2006: Creating Surfaces GameEXlogo Text
00:48:34.8 15/05/2006: Creating Surfaces Toolbar
00:48:34.8 15/05/2006: Creating Surfaces Backgrounds
00:48:36.0 15/05/2006: Creating Surfaces Toolbar Controls
00:48:36.0 15/05/2006: Creating Surfaces GameEx Logo
00:48:36.0 15/05/2006: Creating Surfaces Home & Exit
00:48:36.0 15/05/2006: Creating Surfaces Snaps
00:48:36.0 15/05/2006: Creating Surfaces Menu and List Bars
00:48:36.1 15/05/2006: Creating Fonts
00:48:36.1 15/05/2006: Creating Menu Font
00:48:37.1 15/05/2006: Creating Game Font
00:48:38.0 15/05/2006: Creating Game Font Standard Size
00:48:38.4 15/05/2006: Creating Font Black
00:48:38.5 15/05/2006: Creating Font Black Small
00:48:38.6 15/05/2006: Creating Game Font Faded
00:48:39.4 15/05/2006: Creating Title Font
00:48:43.2 15/05/2006: Creating Control Panel Font
00:48:43.6 15/05/2006: Fonts Created Succesfully
00:48:43.7 15/05/2006: Initialising Windows Media Player Component
00:48:43.7 15/05/2006: MAME Path is: P:\Mame
00:48:43.7 15/05/2006: MAME EXE file is: Mame.exe
00:48:43.7 15/05/2006: ROM Path is: P:\arcade\rom
00:48:43.7 15/05/2006: Catver.ini is located at: P:\Mame\catver.ini
00:48:43.7 15/05/2006: controls.ini is located at: P:\GameEx\data\controls.ini
00:48:43.7 15/05/2006: History.dat is located at: P:\Mame\history.dat
00:48:43.7 15/05/2006: nplayers.ini is located at: P:\GameEx\DATA\nplayers.ini
00:48:43.7 15/05/2006: MAMEinfo.dat is located at: P:\Mame\mameinfo.dat
00:48:43.8 15/05/2006: Loading Controls.ini map file
00:48:43.8 15/05/2006: Loading Custom Emulators
00:48:44.1 15/05/2006: Snap Path is: P:\arcade\snap
00:48:44.1 15/05/2006: AVI Snap Path is: P:\arcade\ingame
00:48:44.1 15/05/2006: Flyer Path is: P:\arcade\flyer
00:48:44.1 15/05/2006: Cabinet Path is: P:\arcade\cabinet
00:48:44.1 15/05/2006: Title Path is: P:\arcade\title
00:48:44.1 15/05/2006: Panel Path is: P:\arcade\Cpanel
00:48:44.1 15/05/2006: Icon Path is: P:\arcade\icon
00:48:44.1 15/05/2006: Marquee Path is: P:\arcade\marquee
00:48:44.2 15/05/2006: MAME CMD options: -triplebuffer -nowindow -joy
00:48:44.2 15/05/2006: Attempting to load game list
00:48:44.3 15/05/2006: Loading last used Game List
00:48:44.3 15/05/2006: Setting Music Volume
00:48:44.3 15/05/2006: Creating DirectSound Device
00:48:44.3 15/05/2006: Trying: Périphérique audio principal
00:48:44.3 15/05/2006: Loading Sound Files
00:48:44.3 15/05/2006: DirectSound Device Created Successfully
00:48:44.3 15/05/2006: Creating ICONS
00:48:44.3 15/05/2006: Restoring Cached ICONS from File
00:48:44.5 15/05/2006: Initialising DirectInput for Gamepad support
00:48:44.5 15/05/2006: Looking for Device: Boîtier de commande à 6 boutons
00:48:44.5 15/05/2006: Device Created
00:48:44.5 15/05/2006: Playing intro sound file
00:48:44.5 15/05/2006: Initializing MCE Remote
00:48:44.5 15/05/2006: Initialization OK! Starting GameEx!
00:48:44.5 15/05/2006: Testing Main Loop Once: Processing Frame
00:48:44.9 15/05/2006: Testing Main Loop Once: Main Loop ran successfully
00:49:02.9 15/05/2006: 21 Consecutive Exceptions Occured: Exiting
00:49:02.9 15/05/2006: Object reference not set to an instance of an object.
00:49:02.9 15/05/2006: at GameEx.GameEx.mainform.PlayLaunchWAV()
00:49:02.9 15/05/2006: at GameEx.GameEx.mainform.LaunchSelectedMAMEGame()
00:49:02.9 15/05/2006: at GameEx.GameEx.mainform.processgamemenu()
00:49:02.9 15/05/2006: at GameEx.GameEx.mainform.DisplayFrame()
Ok what's the problem?
PS: sorry for my bad english but i'm only a poor french guy :P
:) Hi, thank tom
I change the theme and try the others
Only the "Women We Love To Play" theme crash the software!
Maybe GameEx don't like woman! :lol::lol::lol:
I am just finished to download and install the "Bubble Bobble" theme and its work fine with it!
